Rear hydraulic on Kubotas the less expensive way
   / Rear hydraulic on Kubotas the less expensive way
Open system, that means fluid is always flowing thru, and is detored when you open the valve lever to the cylinder you want to acttivate, which in turn is still creating the loop, cause the fluid going in the cylinder is pushing it out on the other end and back into the system. I made this peice on a drill press, a good quility one. Just make sure you do a mirror image to the stock your using , very important. email me for more information or questions. traftonbell@wmconnect.com. The valve bank I bought is a 3 spool from prince , I paided $146.00. Plenty good for my use. And most of you guys also.
RAKE ATTACHMENT FOR MINI-EX (A55745)
RAKE ATTACHMENT...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A57024)
2017 Yale GLC050VX...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Yanmar YT359 (A53317)
