Rear remote for DX40
/ Rear remote for DX40 #1
Jimmy Joe
Medford Wisconsin
I want to add a rear remote hydraulic valve to my 2008 Case DX40, does anyone know what the Case part number would be? I have been trying to search but not much luck I think there is a different part number for each one you add. I currently have none on my tractor.
/ Rear remote for DX40 #2
I've had good luck with this site:
Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
/ Rear remote for DX40 #3
Do you just want Case valves or will a third party valves work for you.
Is your tractor open center or closed?
How many spools do you want.
Will you install T-N-T at some time?
There are lots of valves to choose from, some with float, some with detent, etc.
Thanks for the thread to the site, it helped me determine the valve I was looking at is valve #2 whu=ich wouldn't do me any good without valve #1. It has a new part number it says to replace the obsolite part, not sure what that means. Also J.J. I'm not sure which system I have I googled open center just not sure how to determine which one I have.
/ Rear remote for DX40 #5
If you were to install a hyd gage in the IN port in a tee, you can tell what system you have.
An open center with all valves in neutral will have no or very little pressure.
Open center valves usually have a relief valve.
Closed center hyd system will show full pump pressure or a stand pressure.
/ Rear remote for DX40 #6
Would you happen to have a dealer nearby? If not, Messicks has a great parts center online. You will need the 1st position valve. It's very easy to install, i just did mine this summer.
/ Rear remote for DX40 #7
Hello, I have the same tractor looking to add a rear remote :) did you have any luck? I have a loader on it also. Thanks!
I never did get any rear remotes couldn't get over the price for how often I would use them.
/ Rear remote for DX40 #9
You know you can add an aftermarket valve and do your own plumbing for a few hundred bucks. I've done that on many different tractors. It's easier than you think, and much simpler than adding all the factory stuff. (most of which is unavailable anyway)
/ Rear remote for DX40 #10
Thanks Harry! For someone that doesn't do in-depth mechanics but not worried to try it :) have you come across any recommended You-Tube videos?
/ Rear remote for DX40 #11
I'm really not into U tube videos. I get tangled up in some now and again, but when it comes to those tractor related, I usually disagree with much of what they put out, so why waste my time? Often different videos on the same subject will go in different directions.
If you're interested in tackling it, I can work with you if you like.
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
2000 Peterbilt 378 Tri-Axle Dump Truck (A59230)
2000 Peterbilt 378...
1992 22ft Bayliner BYQ Boat w/ ASPT T/A Boat Trailer (A59231)
1992 22ft Bayliner...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
