Rear Remotes and Grapple on a 2610
   / Rear Remotes and Grapple on a 2610 #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Just wondering how anyone is running their hoses from the rear remote to the front of the loader for a grapple? I want to get one in the spring and would like to run the plumbing over the winter. Both my remotes are not detent. Thanks.:thumbsup:
   / Rear Remotes and Grapple on a 2610 #2
We offer our FHK Kits for running a Front Hydraulic Option off the rear remotes. Our kits inlcude all of the hoses, fittings, quick couplers, and custom brackets to add an additional set of quick couplers at the loader bracket, and a set of quick couplers at the Front Loader Torque Tube. This allows you to remove the Front Loader without having to remove your hoses.
   / Rear Remotes and Grapple on a 2610 #3
I have a grapple on my Branson 8050 and I ran hoses from the rear remotes to the front disconnects for the grapple, works fine, you do have to let go of the loader joy stick and reach over to the remotes lever at times a joy stick button would be nicer but it would be an expensive nicer.
   / Rear Remotes and Grapple on a 2610 #4
Michigan Iron's kits do work well. About 8 years ago, they made a kit for my CK30hst. Hoses from the remotes to an add on bracket at the fel mount disconnects with two additional disconnects. Two shorter hoses to run along the loader arms to another bracket at the front of the fel arms with two more disconnects. This allows you to remove the fel without any hose removal. Just disconnects like factory.
   / Rear Remotes and Grapple on a 2610 #6
MIE do you make a kit for the ck2510?
   / Rear Remotes and Grapple on a 2610 #7
southernAL, here's another option for ya. Also, anything on our website will ship free to the freight terminal in Dothan.
We sell tons of these Custom 3rd Function Kits for Kioti tractors. Take $50 off when you order one with a grapple.
Travis
Our two most popular grapples for the 2510:
The new 200 pound Wicked Grapple Rake is shown here on a CK35.
The 50" Wicked Grapple, which is still under 300 pounds! Roy in GA has one on his CK2510 and he shows it off well.
   / Rear Remotes and Grapple on a 2610 #8
I think I'd prefer a 3rd function with a button on the joystick, but some guys with Kioti tractors find it sufficient to use the rear outlets because of the convenient lever location. These pics are by TBN member James koua.
Travis
He has our 50" Wicked on his CK35.
   / Rear Remotes and Grapple on a 2610 #9
How difficult is it to install one of those 3rd function kits?
   / Rear Remotes and Grapple on a 2610 #10
We have Electric Selector, Front Hose, and continous Power-Beyond metered flow 3rd Function Kits, for all of the KIOTI tractor models. Our continous PB 3rd Function Kits with metered flow will be for sale later this fall.
Thanks for your interest
Hyster H225E (A47384)
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2018 FREIGHTLINER CASCADIA SLEEPER (A56129)
2018 FREIGHTLINER...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
