roadhunter
Elite Member
The stuff I haul is centered. Once again if I had a trailer with say 2,000 pounds on the driver's side and 10,000 no the passenger side then yes I see the benefit of running different pressures. ?
Do you think your load stays centered when you go around a curve? What about a clover leaf? Exit ramp? Corner?
You load shifts when going around a corner, cloverleaf, exit ramp, etc..... That is a fact. More weight is on the outside axle. That is a fact.
When you have 2 bags connected with hose and put more pressure on 1 bag the air moves to the other bag. That is a fact. When this happens while going around a cloverleaf your air bag system will actually be creating body roll instead of giving you side to side stability.
