Rear Tires 2515
   / Rear Tires 2515 #1
JonnyRed
North Georgia
5835R Branson
Is there any width gained by flipping rear tires on 2515?
   / Rear Tires 2515 #2
I'd check the manual to see if it's advisable; otherwise, you can measure the offset on both sides of the wheel to see - put a board across the tire vertically and measure the distance to the wheel under the bolts, and do the same on the inside of the wheel, and compare.
   / Rear Tires 2515
Not in the manual, I'll measure.
Thanks
   / Rear Tires 2515 #5
I can't find the specs (Branson keeps making their web site worse) but from the brochures it looks like a lot of 15 series, maybe all with R4s, use the non adjustable rear wheels. For those you'll need spacers to widen the track. Dave's Tractor in Red Bluff CA has them. Probably other dealers too, though I think they're not a factory part and Daves gets them made locally.
   / Rear Tires 2515 #6
My R1s on the 4815 are adjustable.
   / Rear Tires 2515 #7
Yes. If the tractor comes with R1s, the rear rims are adjustable.
Over here, if the tractor comes with R1 Radial tires, both front and rear rims will be adjustable.
   / Rear Tires 2515 #8
Good info guys, I'm currently looking a getting a new Compact tractor and the Branson seems to be so Dam Narrow in the rear end compared to some of the others I'm looking at.
   / Rear Tires 2515 #9
The width specs for tractors often are for R1 tires, with the adjustable wheels set who knows where. Kubota seems to post more comprehensive numbers. Most people buy tractors with R4s now. The best way to get numbers is to measure them yourself.
   / Rear Tires 2515 #10
I believe most tractors come shipped with their tires set to the narrowest spacing. It's a shipping thing. Fit more cargo (tractors) into less space. I believe it's then up to the receiving dealer to adjust the spacing on tractors sitting on their lots.
If you look at the rims of the tractor you're looking at, it should be pretty obvious by looking at the rim pattern that they either can, or can't be widened by flipping them.
Here's a pic of my back rim, pretty obvious on this one:
I don't have as good a closeup of the front rim, sorry. But you should be able to see the center section of the rim is offset (or dished):
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2009 Sterling AutoCrane 10006H 5 Ton Mechanics Crane Truck (A52377)
2009 Sterling...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
2018 Bell B30E 30 Ton Articulated Dump Truck (A52377)
2018 Bell B30E 30...
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
