Rear wheel lug bolts
   / Rear wheel lug bolts #1
bboston
Castor, Louisiana
Ford 650
I need to know how to replace broken lug bolts in rear hub on Ford 650.
   / Rear wheel lug bolts #2
Only ones I've dealt with where pressed in, I was able to get most out , but ended up taking the hub to a mechanic shop that was able to use a press to remove the bent one. They also pressed the new ones in for me.
   / Rear wheel lug bolts #3
do you have the hub off the tractor onthe bench, or will you be doing it on tractor?
and do you have a hole saw? :)
   / Rear wheel lug bolts #4
There are a lot of different styles of hubs, a pic would make it easier to tell what you have.
NAPA is a good source, most stores can have the studs in a short time if not in stock.
   / Rear wheel lug bolts #5
650 only has 1 style of hub...
   / Rear wheel lug bolts #7
I'm thinking this was a "drive-by" post:laughing:
   / Rear wheel lug bolts #8
i hope not...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
