rebuilding PTO yoke and cross
   / rebuilding PTO yoke and cross #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
Now that I got the tractor side yoke from the old manure spreader working I need to re-attach it to the cross. My issue is the spring clips that hold the thing together. I have the type that has the spring clips on the outside ends of the caps. The caps are 7/8" dia. I am assuming the 1" clips I found at Lowes will fit. I noticed they are about half as thick as clips made for a PTO. Can I stack two clips together or do I need to keep looking for the correct clips? TSC didn't carry what I need.
   / rebuilding PTO yoke and cross #2
Check with your local Napa auto store. I bet they have the proper C clips.
I have noticed people on this list always refer to NAPA to get parts. Is there a big difference between NAPA and Autozone? I am hoping Autozone has these clips since they are more abundant than the NAPA stores around me.
   / rebuilding PTO yoke and cross #4
Usually the universal joint kit comes with those. Maybe you didn't require all new joints?
Autozone carries mostly just things for the average DIY mechanic. NAPA carries a much larger selection of "more advanced" things. Not sure that's the right way to word it. I guess you could say Autozone either has something or they don't. With NAPA, it seems like no matter what you need they have a book to find it and they'll get it for you.
I don't need all new parts. I was trying to resurrect and old PTO shaft. The coupler to the tractor was so badly rusted I did not think I could salvage it. A friend of mine got the yoke off the cross then thought he would give the locking pin a try. With some heat and oil he got that working. So I took a file to the splines to remove the rust and now I have a working coupler. Since the caps and cross are fine I just need new spring clips since the old ones were destroyed when removed.
I will cross my fingers that Autozone has the clips. If not I guess I will be packing the kids up for a little ride to a NAPA store on Sat.
   / rebuilding PTO yoke and cross #6
NAPA was able to identify the u-joint. It is a precision 853. The problem is no one will sell me spring clips with out getting the whole joint. $45 for a set of spring clips just seems pretty steep. I also tried an independent tractor dealer and he only sold whole units also. So TSC is the only place I have found that sells just spring clips but they don't carry ones for 7/8" caps.
   / rebuilding PTO yoke and cross #8
check to see if you have a driveline shop any where close to you they probobly have them laying around give them a couple of bucks to buy a soda and they will more than likely give them to you.
I will check to see about a drive line shop but I have it together with a couple clips from Lowes. Is there any reason they wont hold?
   / rebuilding PTO yoke and cross #10
should be ok :thumbsup:
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
SDLanch SDLLM500 (A53316)
SDLanch SDLLM500...
Link Belt Auger (A53316)
Link Belt Auger...
1999 Caterpillar CS-433C 66in. Vibratory Dirt Compactor Roller (A55787)
1999 Caterpillar...
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A55788)
2006 Mack CT713...
Toro Zero Turn (A50324)
Toro Zero Turn...
