Rebuilding the cylinder on my hoe stick
   / Rebuilding the cylinder on my hoe stick #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
Thought I'd share some pics on my latest repair.
I have a 1998 Ford/New Holland 555E Loader Backhoe. The first cylinder on the hoe stick started leaking a few weeks ago and has been getting progressively worse.
Eddie
Hopefully you can see the fluid leaking from the seals along the top of the cylinder. This is at rest with the engine off, it's still leaking. When I'm using it, the fluid is just running out.
Eddie
This is only the third cylinder on the backhoe to go bad on me, but I've rebuilt five on my dozer. I've gone through a trial and error process to get to this point.
Getting the right tool to take off the ends was a huge pluss. This one came from Case and cost $80. My original 3/4 inch breaker bar was a Harbor Freight model. Cheap, but not very strong. I twisted the drive on it trying to get a previous cylinder off.
This breaker bar is a Proto. It will handle a one inch pipe for added leverage without any problems.
Eddie
I learned the hard way that it's much easier to get them apart when still attached. Once the end cap is loose, I can take out the pin holding the piston end. The other end will stay on.
Since this pin is also holding on the next cylinder, I left it in to supppor that cylinder.
Eddie
The hydraulic lines have to be disconnected to relieve the preasure on the piston. Otherwise, it will never come out. Don't ask how I learned this one. /forums/images/graemlins/blush.gif
Eddie
Even with the hydralic lines off and no oil preasure, I couldn't pull the piston out. Just too heavy, so I attached a come-along to pull it out.
Eddie
It's much heavier than I expected. Easily over 100 pounds.
I put one end in the vise and support it with a ladder. This seems to be the best way to hold it that I've come up with.
Eddie
   / Rebuilding the cylinder on my hoe stick #8
Yikes, that is heavy duty and too much work for the tools I have, I'd have to replace it or have someone else rebuild it for me.
You can see at least part of the problem in this picture. I'm sure the other gaskets are worn out too.
There's a nut ont the end that holds the piston on. My biggest socket is 1 11/16 and it's too small. My tape measures it to be 1 15/16, so I'm off to buy another expesive socket that will probably never get used again. /forums/images/graemlins/smirk.gif
Eddie
   / Rebuilding the cylinder on my hoe stick #10
Eddie, I have just used the hyfraulic pressure to blow the piston out.
Sort of messy but works /forums/images/graemlins/smile.gif
Ben
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
Massey Ferguson 9250 (A55301)
Massey Ferguson...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
