Recommend a HD box blade for land clearing chores (please)
   / Recommend a HD box blade for land clearing chores (please) #31
Looks like a darned good deal to me.:thumbsup:
   / Recommend a HD box blade for land clearing chores (please) #32
Yeah, he's makin' everybody jealous with that one! :thumbsup:
   / Recommend a HD box blade for land clearing chores (please) #33
Glad to have helped. I just found another near by. It looks to be the same model Jenkinsph has. Also a good deal.
Matt:thumbsup:
   / Recommend a HD box blade for land clearing chores (please) #34
Looks very nice Piston. I would bet that the hydraulics are fine with no leaks. That stuff lasts a long time and yours has hardly even been used. :thumbsup: I would hook it up and use it as is, well actually I would paint it shortly after I used it first. You got a great deal. :cool2:
I have to admit I was a little worried with buying something so far away sight unseen.
I was looking over my manual for my tractor, and in the manual it lists all the different sized implements (max weight) that are recommended for the tractor. Under the 'box scraper' section it lists a weight of somewhere near 750lbs as the max weight (don't remember off the top of my head exact numbers)
I was a little surprised it listed the weight so low and I know a lot of people use much heavier box blades than this on similar sized tractors. Should I be worried about that at all since the box blade is 1,000lbs? My rear lift capacity is just over 2,500lbs.
One thing I like is that it has the hinged blade, which I wasn't originally looking for, but I can secure it with 2 half inch bolts to make it fixed. I'm going to read through some more 'using a box blade' threads to figure out how to use it. I've never used one before, in fact this one hasn't even been hooked up to the tractor yet.
Jake,
I noticed you have a John Deere 410. How do you like it? My father and I have one but haven't owned it long. We sold an old Dynahoe and bought the 410 from a friend. I'm excited to get it up to my land in NH and see what it can do. Is yours 4wd? Mine is only 2wd unfortunately.
Thanks for the comments and letting me know that I made the right decision on buying the box blade!
   / Recommend a HD box blade for land clearing chores (please) #36
Piston,
Looks like a great deal to me, and I would also doubt you have any problems with the hydraulics. It appears to lock the scarifiers in place similar to mine so less stress on the hydraulic cylinder. FWIW, I don't even need the scarifiers for most things because the box is heavy enough it will cut easily.
The rear hinged blade works great and produces a nice smooth finish. With a good top n tilt setup you will be ready to go. I haven't seen the need to lock down my hinged rear cutting edge.
   / Recommend a HD box blade for land clearing chores (please) #37
That's a really nice box blade and the deal you got makes it even better, you won't find deals like that everyday, good job searching for it!
2014 Ford Escape (A50323)
2014 Ford Escape...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
Toro Workman Utility Cart (A51694)
Toro Workman...
2024 JOHN DEERE 1025R LOT NUMBER 163 (A53084)
2024 JOHN DEERE...
