Relieving Pressure in FEL Hoses
   / Relieving Pressure in FEL Hoses #21
Jim your right pressures do indeed build quickly as the ambient temperature increases or the sun beats down on the parked loader or backhoe cylinders. It's pretty easy to deal with it though if you expect the problem upfront.
It's a bear however if you ignore the problem and try to make the connection under pressure.
   / Relieving Pressure in FEL Hoses #22
</font><font color="blue" class="small">( Being sprayed by hydraulic fluid is a good way to stain your clothes, )</font>
It can be more serious than that. The pressure can be high enough to inject hydraulic fluid under the skn. This tends to cause gangrene. Hydraulic fluid is nasty stuff.
John Deere has a warning in their manual that, if this happens, you must seek a doctor immediately, who has experience in surgically removing hydraulic fluid from your tissues. Failure to get immediate nmedical attention can result in some massive necrosis.
They have a hotline number in the manual to find a knowledgable physician in your area.
   / Relieving Pressure in FEL Hoses #23
Relieving the pressure in a disconnected FEL hose probably would not cause any harm to skin. Now hoses under pressure from the pump, well that's a different story.
   / Relieving Pressure in FEL Hoses #24
</font><font color="blue" class="small">( Relieving the pressure in a disconnected FEL hose probably would not cause any harm to skin. Now hoses under pressure from the pump, well that's a different story. )</font>
Don't take the chance!
Hydraulic fluid is some nasty stuff...
   / Relieving Pressure in FEL Hoses #25
Best thing is to get a solid place for your bucket so it won't move while sitting. And even then you may run into some trouble. There was times I had to take the ends off to get the pressure out. I hit the end so hard against the loader I even dented up the tit.
I really hate to admit this guys but Pineridge has a pretty good idea. Now you didn't hear this from me /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif And Pine you don't need to go home and brag to your wife that you had a good idea!! /forums/images/graemlins/laugh.gif
murph
   / Relieving Pressure in FEL Hoses #26
<font color="blue"> I really hate to admit this guys but Pineridge has a pretty good idea. Now you didn't hear this from me And Pine you don't need to go home and brag to your wife that you had a good idea!!
</font>
I'm printing, and framing this post.... /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/cool.gif
   / Relieving Pressure in FEL Hoses #27
LMAO /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
murph
   / Relieving Pressure in FEL Hoses #28
The issue is not so much the toxicity of the fluid as the damage caused to the cells by the pressure. The cells get squished into a pulp. You can get the same type of injury and its just as serious if you get injected by high pressure clean water from a pressure washer or latex paint from an airless sprayer.
The dead tissue can go quite deep. Its also hard to determine how much damage there is and where it all is. That dead tissue is perfect for growing nasty stuff. Growing nasty stuff deep in your tissues is bad for your health.
- Rick
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2000 POLARIS MAGNUM 325 4-WHEELER (A51406)
2000 POLARIS...
Kubota M4700 51HP Utility Loader Tractor (A55787)
Kubota M4700 51HP...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
