Remote Hydraulics on Ford NAA
   / Remote Hydraulics on Ford NAA #21
I was wondering if you could just run it off of the Bleeding thing on the top of the transmission (I am not sure about this as i have never used it) but the naa i have has been in the family its whole life and has had a loader on it back in the day. the loader was ran off of this i think due to my seeings of the set up You would have to chain the threepoint and would need to find a spring to return the splitter The piece is out of the top of the transmission and has a 90 on it then its sealed with a plug
   / Remote Hydraulics on Ford NAA #22
I assume you are talking about an elbow on top of the top cover(hydraulics) and not the transmission. The loader was probably a hydraulic lift with no down pressure, a gravity down with a trip bucket. You would have to find some way to return piston. It's painfully slow. With a 3pt splitter it would be harder to chain down the 3pt but not impossible. I don't think you will be happy with this system but it's your call.
kirk
   / Remote Hydraulics on Ford NAA #23
i just chain thru the knuckles to the axle.
agreed.. slow.. but does work.
i have 1-arm laoder on a naa with a modified top cover and a logsplitter valve.
2.8gpm baby.. :)
   / Remote Hydraulics on Ford NAA #24
You hit the nail right in the head and those were the problems that i was thinking about but it is an option
   / Remote Hydraulics on Ford NAA #25
I have remote on mine, don't chain the 3 point either, it is all through the plate under the seat, have to plug 1 port and drill and tap another externally. Slow but it folds my 4 rotor tedder, and will lift the cutter head on my mower, that's all I really wanted anyways. Here is how I did it.
http://www.ntractorclub.com/howtos/pdfs/RemHydrMod2.pdf
   / Remote Hydraulics on Ford NAA #26
yep.. that top cover plate mod is a good one. it's what I did on my naa.
CASE 6591 T/A PORTABLE POWER UNIT (A51243)
CASE 6591 T/A...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
1266 (A50490)
1266 (A50490)
2010 DODGE RAM 2500 FLATBED TRUCK (A51243)
2010 DODGE RAM...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
