Remote Start
   / Remote Start #11
Make sure you get something with good range, 1000+ ft would be a minimum. The actual range drops a lot in parking lots with other cars around. I think the last one I got had a 2000 ft range and was great. Also by all means, let a pro install it, the new vehicles have so many anti theft devices that need to be worked around its not something that I would want to try, and I try some stuff that I shouldn't. But as I get older, I'm getting wiser..:D
   / Remote Start
You are right, I will get someone to install it.
   / Remote Start #13
My last two GMC's had it..Love it..Factory on mine, but the aftermarket pro-installed work every bit as good according to those that have them.
   / Remote Start #14
Has anyone installed or had a remote start installed?
I had a Compustar with the Slice remote, Click Here, installed about a month ago. As others have said, have it professionally installed and get the most range you can afford. Two way remotes are nice as well. The Slice remote I got not only 'tells you' it sent the command but that the vehicle responded. The only thing inconvenient about my cars security system and the remote start is, when the car is remote started, it shuts off when any door is opened. There was no way to 'program' around this.
   / Remote Start #15
i've never seen a remote that operated in this way, not syaing yours doesn't.
that's a strange way to program the thing. on mine I can open the door, get in,
but if you do anything with any control (gear shift, brake pedal, etc.) the turck will
shut off. need to put the key in and turn to run first.
wife's car works the same way.
   / Remote Start #16
i've never seen a remote that operated in this way, not syaing yours doesn't. that's a strange way to program the thing.
Just to be clear, it's not the remote start module that causes this, it's the security system in the car.
   / Remote Start #17
I've installed about a dozen or so in past 10-12 years Fords, GM and Mazda, (Pro-Start Canadian Tire) never had a problem yet (knock on wood) Everyone says have a pro do it. I've seen two instances of 'pros' fail, the reason being is they use those cheap ***** scotchlock connectors for tapping into existing wires because they're fast. They cut thru a good portion of the wire you're tapping into causing resistance which in turn causes heat and so on. Any I've done I solder and heat shrink every connection.
The Pro Start comes with a link to the wiring schematic page, if you get a unit that doesn't have any car specific info here's a link to a good site http://tinyurl.com/nv9o6h6....Mike
   / Remote Start #18
Then the person didn't properly evaluate the installer. :) I looked for online reviews, industry awards, etc., which pretty much eliminated big box stores.
   / Remote Start #19
I have it on both of our vehicles.We are into an ice storm..had an inch and a half of ice on my truck.
Remote start and warm up,,had to do it twice before I could open the door.Of course the wife's is in the garage.
   / Remote Start
Thanks for the suggestions.
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
UNUSED FUTURE FT-ZP210 20' X 30' ALLSTEEL GARAGE (A57193)
UNUSED FUTURE...
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
UNUSED FUTURE XGJ 40" HYD ROTARY TILLER (A57193)
UNUSED FUTURE XGJ...
2011 JOHN DEERE 544K WHEEL LOADER (A52707)
2011 JOHN DEERE...
