Remove bush hog blades with cordless 3/4 impact wrench?
   / Remove bush hog blades with cordless 3/4 impact wrench? #21
-Dieselbound- FYI; I got the HF 3/8 earthquake impact and I am pretty impressed with it.
HF didn't have the 1/2" in stock. They had a spot on the shelf but no product. Sounds like a new order is on the boat... And, of course, my 1/2 impact didn't faze the stupid nuts! Tried heating them (one of them anyway) up and still nothing. I'd been soaking them for days.
   / Remove bush hog blades with cordless 3/4 impact wrench? #22
Forget the impact wrench. Get a nut splitter kit. They are fantastic things and much cheaper than a rattle gun. You dont have to split the nut. Just apply pressure to a couple of facets of the nut and it will break the bond so the the nut will come off easily with an ordinary spanner. You can usually re-use the nut afterwards. I have used these on 'salt penetrated' nuts that were so rusted that no amount of heat or soaking or rattling would remove.
   / Remove bush hog blades with cordless 3/4 impact wrench? #23
Had to change mine after we broke a blade on a rock (probably a lot of rocks). We used PB Blaster for a few days, a 24" breaker bar, and a 3' pipe extension.
   / Remove bush hog blades with cordless 3/4 impact wrench? #24
That new Hampshire Granite will do a number on steel blades. That is the worst blade I have ever seen.
   / Remove bush hog blades with cordless 3/4 impact wrench? #25
Not sure if I could get one of these in there, working above the stump-jumper plate. Might be time to start thinking about dropping the plate and the blades and just taking it somewhere. Right now this is just a low priority item on my huge list/
   / Remove bush hog blades with cordless 3/4 impact wrench? #26
Of course you will likely be doing yourself a big favor later on to pull the jumper first . It's easy to get at and best of all if you toss a gear box you will be glad it came off once in a while so you can manage to get it off at all. I put Never Seize on those sort of things. They have a cotter anyways so they aren't going to loosen up and fly away.
   / Remove bush hog blades with cordless 3/4 impact wrench? #27
Fair enough. You do need good access to use a nut splutter.
Another cheap option is to weld a socket to a piece of pipe, then use a pipe wrench (with an extension pipe if necessary) to turn the nut. Its a lot stronger than your average 1/2" socket bar.
   / Remove bush hog blades with cordless 3/4 impact wrench? #28
Got the castle nut off for the stump-jumper but then wasn't able to get that off: I didn't spend a lot of time. I purchased a 1/2" NitroCat from NorthernTool and it was able to break those blade nuts/bolts loose! At first I was having doubts whether it was going to work, but, thankfully, it did it. At 1,200 ft-lbs I would think that this impact gun is likely to be able to handle just about any such nuts/bolts.
(3) FIBERGLASS LADDERS (A58374)
(3) FIBERGLASS...
2012 LAND ROVER Range Rover SUV (A56859)
2012 LAND ROVER...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
1979 HEIL TRANSPORT TRAILER (A58214)
1979 HEIL...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
