Removing a hydraulic joystick knob
   / Removing a hydraulic joystick knob #1
RHughes
Autauga County, AL
New Holland TN65
I need to replace a cracked boot on my FEL joystick but cannot for the life of me see how to remove the joystick knob without destroying it. It's not threaded on and I do not see a set screw.
Any ideas would be appreciated.
Thanks!
   / Removing a hydraulic joystick knob #2
Yours looks different, mine is (was) soft rubber. It was cast in place and I had to saw it off with a hacksaw. That was to replace it with a third function knob.
Have you tried removing the whole lever, though, and replacing the boot from the bottom?
   / Removing a hydraulic joystick knob #3
I think this is the ticket. Lift the boot and tackle it from the bottom.
   / Removing a hydraulic joystick knob #4
I have taken mine off on a Kubota L3010 but yours is probably different. It was a while back but I remember twisting it first with a lot of force then when it moved I had to push it off twisting because pulling just tightened it. Mine is hard rubber not molded plastic.
gg
   / Removing a hydraulic joystick knob #5
gg
Mine are like yours... Twist, pull and cuss a lot.
Thanks for the ideas!
I think I'll try and tackle it from the underside. I tried the "twist-off" approach but was concerned about breaking something.
16001 (A55853)
16001 (A55853)
White 6175 Work Horse Tractor (A59814)
White 6175 Work...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
