Removing a hydraulic joystick knob
   / Removing a hydraulic joystick knob #1
RHughes
Autauga County, AL
New Holland TN65
I need to replace a cracked boot on my FEL joystick but cannot for the life of me see how to remove the joystick knob without destroying it. It's not threaded on and I do not see a set screw.
Any ideas would be appreciated.
Thanks!
   / Removing a hydraulic joystick knob #2
Yours looks different, mine is (was) soft rubber. It was cast in place and I had to saw it off with a hacksaw. That was to replace it with a third function knob.
Have you tried removing the whole lever, though, and replacing the boot from the bottom?
   / Removing a hydraulic joystick knob #3
I think this is the ticket. Lift the boot and tackle it from the bottom.
   / Removing a hydraulic joystick knob #4
I have taken mine off on a Kubota L3010 but yours is probably different. It was a while back but I remember twisting it first with a lot of force then when it moved I had to push it off twisting because pulling just tightened it. Mine is hard rubber not molded plastic.
gg
   / Removing a hydraulic joystick knob #5
gg
Mine are like yours... Twist, pull and cuss a lot.
Thanks for the ideas!
I think I'll try and tackle it from the underside. I tried the "twist-off" approach but was concerned about breaking something.
Woods 18ft Batwing Rotary Cutter (A56438)
Woods 18ft Batwing...
JCB 509-23TC TOOL CARRIER TELESCOPIC FORKLIFT (A60429)
JCB 509-23TC TOOL...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
Kubota L4701 (A53317)
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
