Removing floor of Grand L?
   / Removing floor of Grand L? #1
vvanders
Platinum Member
Sequim, WA
Kubota L4760
Went to go crank the L4760 this afternoon and was greeted with a couple errors on the dash around PTO switch and F/R HST sensors not working correctly. Shut the machine down and took a look, somehow a rat took up residence right under the floorboard behind the steering column. Argh.
Looking at the WSM it seems like it got only one of the wiring harnesses(PTO and HST are on same cable). The transmissions section describes how to remove the floor, however it seems to require a hoist and removing the seat + all rear linkages.
Is there a simpler way to get access? The tractor is outside, uncovered and I can't move it(unless you count using the loader to push it). I'm handy enough to splice the harness back together but getting access seems like a royal pain.
   / Removing floor of Grand L? #2
fried1765
Super Star Member
Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I store all my engine powered machinery inside, and with DeCon attached.
If you are concerned about domestic animals, just put the stuff somewhere your animals can't reach it, and tie it on.
   / Removing floor of Grand L? #3
Hilbilly
Veteran Member
Barriere, BC
Kubota Grand L6060HSTCC
I wish I had some advise but unfortunately I don't. I would however like to know what "Decon" is. I've had some problems with pack rats in the past and would like to avoid more in the future.
   / Removing floor of Grand L? #4
shovelmike
Platinum Member
Rural Missouri
Ferguson TO35 , Mahindra eMax 22, Hustler Super Z
Decon is pellets (grain based I suppose, attractive to rodents) laced with coumarin (a blood thinner), it causes the rodent to bleed internally and die.
   / Removing floor of Grand L? #5
rbargeron
Elite Member
MA
L5450, L48, L3250, L345
Edit: post below is right - mine was prunes.
   / Removing floor of Grand L? #6
The Fred
Veteran Member
hOOterville
Boost it and Lose!
I think he's talking 60 series not 40.
On the 40s you can pull the steering shaft and clutch pull rod then 2 front cab mount bolts and carefully jack the front of the cab on both sides (2 people) and support with 5 x 5 wood blocks between the cab and frame mounts.
Much easier access to wiring and no seat removal needed. My guess is that 60 series is different because of the fuel tank and things.
OP
V
vvanders
Platinum Member
Sequim, WA
Kubota L4760
Yep, rather than try to jury-rig anything turns out KTAC covers "infestation" so just going that route.
Only downside is looks like I'll be without a machine for about a month or so.
