Removing floor tiles is HARD WORK!
   / Removing floor tiles is HARD WORK! #1
jymbee
Platinum Member
Upstate, NY
Massey 1652, 1949 Farmall H
The hard vinyl 12" square tiles that were installed over our concrete basement floor now need to be removed for new flooring. Whatever glue was used is proving to be quite a challenge. Best I can do with a hammer & pry bar is to chip off pretty small pieces with each whack-- with quite a bit of effort at that. Using a heat gun helps a lot but that's pretty time consuming-- having to hold the heat in place and work it over each tile for quite some time to soften them up.
I don't expect there's any "trick" to making what looks like a long, arduous job much easier but perhaps someone has found a better way to remove this old flooring?
   / Removing floor tiles is HARD WORK! #3
Electric chip hammer(aka small jackhammer)with flat blade will makeum give up their milk.
   / Removing floor tiles is HARD WORK! #4
Rent an electric floor tile remover.
   / Removing floor tiles is HARD WORK! #6
A sawzall with a scraper blade might work.
   / Removing floor tiles is HARD WORK! #7
I did that once and still had a problem.
   / Removing floor tiles is HARD WORK! #9
Try a spade.. worked for me
   / Removing floor tiles is HARD WORK! #10
I was buying some stuff from a guy in Orlando on ebay, and noticed a piece of equipment with no bids, so I stuck a "starter bid" in on it, figuring the electric motor was worth $25.00. Asked the wife, and she said it was ok to bid on it, and that my sister in law was going that way and could pick it up. So I ended up buying it. I got a phone call from the wife a couple days later, asking me if I knew what that machine was called, and I said no. She said it said "The Stripper" all over it. So basically, my wife OK'd me buying a $25.00 stripper, and had my sister in law deliver it.
Darn thing set around here for a couple of years till my Pastor went to remodel his house. I told him I had a $25 stripper he could use, and according to him, it worked really great on ceramic tile floors. Then my Mom called and told me my brother was trying to pull the parquet floor out of her den, and I grabbed the stripper and impressed Mom with it. Nowadays it just sits in the garage, waiting on somebody else to need a $25 dollar stripper.
Basically it is an electric motor powered vibrating blade with a weight on wheels.
Rent one, works great!!
David from jax
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
International 424 Loader Tractor (A59814)
International 424...
2020 CATERPILLAR 302.7D CR EXCAVATOR (A60429)
2020 CATERPILLAR...
