removing lever ends
   / removing lever ends #1
pedalstomper78
Ohio
Case/IH DX33
It looks like I have to pull apart the rear end of my Case DX33 (think of it as a red TC33DA.). To get the fenders off.....how do the balls on the ends of the selector levers (rear and mid PTO, 3point and hydraulic remote controls, etc) off? I see no fasteners on them and it doesn't look like they can be pulled off without breaking them. Any help woukd be greatly appreciated!!!!
Please help!!!! LOL
   / removing lever ends #3
I don't know but have you tried to unscrew them? I am just guessing as I haven't seen them.
Unfortunately.....it's flat stock that goes into the knob. Rotation will = expensive lol
   / removing lever ends #5
Take lever of under panel. Knobs are more than likely press fit, which means one time use
   / removing lever ends #7
Carefully heat them with a heat gun or hairdryer if necessary. Use light pulling pressure,should come off without causing damage so that reuse is possible. Heat them up as well for instasllation.
   / removing lever ends #8
If they dont screw off. Use a box end wrench the same size as the shaft. Place the wrench around the shaft under the ball and tap upward. Works for me and tap it back on afterward.
Used thewrench method and it worked great! Thx
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
CAT 289D3 (A58216)
CAT 289D3 (A58216)
22167 (A56859)
22167 (A56859)
JLG 660SJ (A58216)
JLG 660SJ (A58216)
202480 (A54757)
202480 (A54757)
