Removing PTO shaft w/ heat - will Mapp torch work?
   / Removing PTO shaft w/ heat - will Mapp torch work? #11
I agree.. either get it setup using a soft bolt, after dressing those shaft surfaces.. or use a torque limiter.. etc.
Soundguy
   / Removing PTO shaft w/ heat - will Mapp torch work? #12
</font><font color="blue" class="small">( It's off! It took a soaking in BP Blaster, a 5lb sledge and a bad day at work. The bad day work sent me home in a foul mood and beating the crap out of that shaft felt great! I'm sure I would have stopped much sooner any other day. But once I saw a tiny bit of movement, I just didn't want to stop. Only took about 20 minutes of constant pounding. Boy do I feel better! /forums/images/graemlins/grin.gif
I do have a question. The shaft was keyed, but there was also a shear bolt. For safety, should there be one and not the other? I always though it was just held on by a shear bolt. There is no slip clutch.
Thanks, )</font>
If there is no snap ring on the end of the shaft DO NOT use just a shear bolt. If you shear the bolt there is nothing to keep the PTO shaft from sliding off the gearbox input shaft while it is spinning at 540+ RPM. If the shaft has a key way and a bolt hole it is setup for a slipclutch only. Someone probably had clutch trouble and took the cheap way out.
Put a new slip clutch on the mower using both the key and bolt. <font color="red"> </font>
   / Removing PTO shaft w/ heat - will Mapp torch work? #13
He can always drill near the end of the shaft and tap it for a small set screw.. then he will be good to go..
Soundguy
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
TRUCKING INFO (A50775)
