Removing PTO shaft w/ heat - will Mapp torch work?
   / Removing PTO shaft w/ heat - will Mapp torch work? #11
I agree.. either get it setup using a soft bolt, after dressing those shaft surfaces.. or use a torque limiter.. etc.
Soundguy
   / Removing PTO shaft w/ heat - will Mapp torch work? #12
</font><font color="blue" class="small">( It's off! It took a soaking in BP Blaster, a 5lb sledge and a bad day at work. The bad day work sent me home in a foul mood and beating the crap out of that shaft felt great! I'm sure I would have stopped much sooner any other day. But once I saw a tiny bit of movement, I just didn't want to stop. Only took about 20 minutes of constant pounding. Boy do I feel better! /forums/images/graemlins/grin.gif
I do have a question. The shaft was keyed, but there was also a shear bolt. For safety, should there be one and not the other? I always though it was just held on by a shear bolt. There is no slip clutch.
Thanks, )</font>
If there is no snap ring on the end of the shaft DO NOT use just a shear bolt. If you shear the bolt there is nothing to keep the PTO shaft from sliding off the gearbox input shaft while it is spinning at 540+ RPM. If the shaft has a key way and a bolt hole it is setup for a slipclutch only. Someone probably had clutch trouble and took the cheap way out.
Put a new slip clutch on the mower using both the key and bolt. <font color="red"> </font>
   / Removing PTO shaft w/ heat - will Mapp torch work? #13
He can always drill near the end of the shaft and tap it for a small set screw.. then he will be good to go..
Soundguy
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
CAT 973 (A47384)
CAT 973 (A47384)
2003 12FT Paris Utility Tilt Trailer (A52377)
2003 12FT Paris...
MISSION 4X3X14 CENTRIFUGAL PUMP (A53843)
MISSION 4X3X14...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
