Removing Stumps
/ Removing Stumps #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
Here is a stump I removed yesterday. It only took about an hour or two using the backhoe and a tow strap.
/ Removing Stumps #2
Looks like you're putting that machine to good use!
/ Removing Stumps #3
First One... Good JOB! :thumbsup:
/ Removing Stumps #4
By the looks you got good feel of your BX,got feeling your project list shall grow. :)
/ Removing Stumps
Here is the biggest one yet...It may take a couple of days...
Yes, that is me in the pictures. :)
/ Removing Stumps #6
Nice pic's I'm jealous. And want a backhoe for my tractor . I use a backhoe at work and don't think there's anything better to do than dig out stumps and rocks out of the fields
(the bigger the better). Looks like your having way to much fun !
/ Removing Stumps
Believe it or not, it was fun...:laughing:
/ Removing Stumps #11
Look like you have learned the right technique to getting those stumps out. Good Job.
Just curious, is one of those garage doors the one that jumped it your way?
/ Removing Stumps
Yep, the one on the left. If you can see the one on the right, it is down just like the left was when I hit it. The one I hit will be replaced next week. :)
/ Removing Stumps #13
I pulled a stump last week that was just a little bigger. It took me about an hour, but I bet I was more tired than you were.... I used a shovel, root axe and when I got tired of digging and hacking, chained up the stump to my F250 4x4 to break it loose (had 3 tires slip on concrete!). I did (try to) use the FEL on my B7100 to lift it, but it was too heavy with all the dirt in the rootball so had to knock it around and whack away the dirt with a pick until I could lift and carry with my FEL (500lb cap).
Still beat the heck out of when I hand dug a ~2000lb cottonwood stump. It took a couple days (had to rest) of digging and root chopping. I ended up with an 8-10ft diameter hole, 3-4ft deep, then used hydraulic jacks and my Subaru wagon (seriously!) to get it out of the hole.
Playing in the dirt is fun... or at least it sounds like fun after all the blisters have healed!
/ Removing Stumps #14
I have dug out a few stumps, most I didn't need to but what the heck, it was seat time. :licking::licking: Got some time on the backhoe and learned a bit on the best way to dig up stumps. Found that I need to dig a bit a way from the stump to be able to break the roots, doesn't work to well if you dig right next to the stump.
/ Removing Stumps #15
Hey Mousefield, I'm just a little south of you, wanna come practice your technique here? :thumbsup:
/ Removing Stumps #17
Funny I came across this thread while hunting for "todays seat time". I've been recovering a small piece of land that is on a steep slope. It was all small trees and a bunch of some thorny, nasty, flowering things. Anyway, at the bottom, just right to make me always have to turn on the hill, was a 24" pine stump that blew over 4 or so years ago.
Had the forks on to set a new snowmobile bridge for the ITS trail that crosses the property and got a little side tracked with the stump. I don't have a backhoe, but the forks work just as good. Work around the stump and break any roots by inserting the forks under them and lifting, rolling the forks forward, and driving forward slowly. Then get under the stump itself and do the same thing. This is the biggest I have done so far. Don't think I could've done it with a fresh kill.
/ Removing Stumps
Wow! That's a big one...:thumbsup:
/ Removing Stumps
Here is today's work. I finished it in about 3-4 hours total.
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
International Engine (A61568)
International...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
International S1900 (A63118)
International...
(296) 1"X6"X6' TONGUE & GROOVE (A62131)
(296) 1"X6"X6'...
