Neat ideas and methods in that video and it's easy to watch too. I have used the file method and bought some special tubing with the weld removed at a premium price. His simple tools seem to work good. Thanks for posting.
John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
Nothing wrong with his method but I don't see myself spending the time to build a tool every time. As he said the weld is never in the same place.
I've done this with a file or a long nose grinder. I usually use the Long Shaft Die grinder from HF to get as deep as I can then finish with a file if I need to.
What surprises me the most is every local metal fabricator/supplier I have gone to says they just use 2-1/2" x 3/16" wall tube for the outer piece. No way I want that much slop in a receiver. I buy 1/4" wall tube and remove the weld.
Video was interesting, thanks;
For 2" receivers they actually make female receiver tube - it's .030" over 2.5" tube, smooth inside. So 2.530" OD, 2.030" ID; A little more expensive per #, but not THAT much. My local steel supplier stocks it, free delivery for orders over $100 (and yes, one stick IS free delivery @ 151 pounds)
YMMV, but with 2 tractors and a hoe I make a LOT of "tinker toys" with that material and 2" x .250" wall... Steve
