Removing Woods bushhog blades
/ Removing Woods bushhog blades #1
weathda
Alabama
Farmtrac 665DTC, Kubota L2550, John Deere 310SE, Dresser 175C
This weekend I removed and sharpened the blades on my Woods DS96 8' cutter. Had some time, so I shot some video and tried to put together a how-to. It's not rocket science but interesting how Woods designed the blade attachment. I'm not sure its any easier than the typical big bolt and nut on most cutters.
Remove and sharpen bush hog blades - YouTube
/ Removing Woods bushhog blades #2
I have two Woods rotary cutters, I can't imagine going back to the old way of having to deal with a giant nut that never wants to come off!
I thank Woods every time I remove the blades on my Woods cutters!
SR
Yep, it's not bad on the Woods. I suppose if the giant blade bolts are removed often enough they might not be too bad? I recently removed the blades off a Bush-hog brand cutter and we had the flip the cutter up and heat the nut and use a cheater pipe to get it to break loose.
Just wish the DS96 I have had a bigger port hole opening!
/ Removing Woods bushhog blades #4
I am thinking of getting a Woods BB720 so your video was reassuring for me. :thumbsup: I've fought the other brands style of mammoth bolts and that was no fun. I also saw a video that member Eric the Oracle posted somewhere with his Woods, and he had some issues with the shim plates being damaged enough that he couldn't remove them easily. Thanks for the video!
/ Removing Woods bushhog blades #5
I have a Woods BB 72 and a BB 720. The 720 is far superior, and I’ve been pleased. I like the bolt on replaceable skids, heavier steel, and a stronger gearbox. And replacing the blades is easy as the video shows.
/ Removing Woods bushhog blades #6
I changed the blades on my 5' Woods and I believe looking at the old blades they were original.
I don't know how old the cutter is but I bought it VERY USED!
It took very little time and was easy.
/ Removing Woods bushhog blades #7
If you get it flipped up how hard is it to sharpen the blades WITHOUT taking them off?
Ford850, glad the video helps.
Stimw, I'd say you got your mileage out of those blades!
Newbury, I'd say easier to flip it. The DS96 is a little bulky though. It really isn't too bad removing the Woods blades. I was replacing blades on the Bush Hog 5 footer I referred to, so they had to come off. The last time I sharpened the Bush Hog, I just crawled under it with an angle-grinder.
/ Removing Woods bushhog blades #9
I currently have a DS-120, with the small access hole like yours. Might have your "borrow" your method of holding the pin up while installing the keeper.
My old Twin Cadet 121 had a much larger hole with a cover held on by a wing nut. It was large enough that I could drop the blade and pin down through the hole,then pull the pin up through the stump jumper and have room to take my other hand and reach down install the keeper, never having to crawl under the cutter.
Finally uploaded the bush-hog video. The Johnson grass was so tall, the stalks were longer than the deck which made a clean cut near impossible. Had to go over some areas twice.
Farmtrac Bush hogging - YouTube
/ Removing Woods bushhog blades #11
I have a blow by blow video on this as well.
Now, that was much more entertaining, Eric. Yup, same blade attachment. Looks like the BB720 has better access and bigger shims. Next time, I think I'm going to dremel a bit off my shims. I don't know why the hole tolerances are so tight. I found if I could just get them on the edge of the pin, I could tap the pin down so the shim would slide off pretty easy. The left side of my DS96 only had one shim per blade, but the right side had two per blade.
/ Removing Woods bushhog blades #15
I'm in agreement: i don't think the shims need to be that tight. I suspect they are not that tight when new and peen themselves until the pin cannot pass through.
Video wise, i try to keep them entertaining even when i'm obviously floundering. :laughing:
UNUSED SDLANCH MINI EXCAVATOR RIPPER (A60432)
UNUSED SDLANCH...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
CAT 930M (A58214)
CAT 930M (A58214)
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
