Repair/mechanic tricks and or tips?
   / Repair/mechanic tricks and or tips? #181
Hi
Putting Chemicals in a freezer with food could be hazardous to your health if you eat the food.
Charlie
   / Repair/mechanic tricks and or tips? #182
I'd sure hate to sit down to super and find a well cooked paint brush when the tinfoil was unwrapped!:p :p :D
   / Repair/mechanic tricks and or tips? #183
If the wooden handle sticking out didn't give you a clue that it wasn't paper beef or paper chicken then you are so far gone you might as well go ahead and eat the brush.
Now back to reality...
A vacuum is airless and a sure fire way to exclude oxygen but the differential outgassing of the volatile constituents would not have a desired effect on the brushes contents.
Storing the brush in dry air is not going to give the desired effect either. Excluding oxygen is an important issue. A simple way to exclude oxygen is to wrap the bristle end of the brush in foil. My foil is impermeable and with a modicum of care there is a "near" hermetic seal which for my purposes exceeds the requirement.
As far as condensation on the brush when removed from the freezer... I unwrap the bristles and plunge them into the can of finish. I don't unwrap it and let it sit out to become wet from condensation. The stored heat in the room temp finish "thaws" the bristles nicely in short order and you are good to go.
As regards the "hassle" of decanting paint into a smaller container... I haven't found it to be a challenge. There are numerous plastic gadgets available for easy paint pouring without spilling it down the side of the container or filling the groove on top of the can for the compression lid. Decanting to a smaller container reduces the available oxygen which for many finishes is as or more deleterious to storage as the small amount of moisture in air.
I have no quibble with drying the air, it doesn't hurt and may help with some finishes but it does nothing to reduce the available oxygen which is a sure fire aging agent for stored finishes.
Now for another tip:
When you finish off a tube of caulk in a good strong plastic tube, stick your air nozzle (with trigger) into the dispensing end and aim the big end of the tube in a safe direction. Give it a shot of air and the piston will be driven from the tube with quite a force and a pop sound (like a tater gun which can also be built from a used caulk tube.) Not only is it fun but it lets you access the inside of the tube to clean it out. If the contents was silicone, it may be easier to let it cure and then peel it out but water clean up materials are best attached right away with water.
Now you can put whatever material you want to dispense in the tube. Two ways of doing that (there are others) is to use a putty knife and or a spoon to pack the material into the tube. If you have vacuum available you can hook a vacuum line to the nozzle of the tube, stick the big end into the material of interest, and let the vacuum suck the stuff up into the tube.
When the tube is filled to your requirement you put the piston back into the big end and you are ready to dispense the new material. This will work for various products that you might want to dispense but can't find in a tube or the bulk price is far better or it is your custom stuff. It will also dispense heavier paste consistency home brew BBQ sauce, cake icing, mortar, grout, and whatever can be forced out the tip.
Caution with food stuff, you need to clean the tubes well.
Pat
   / Repair/mechanic tricks and or tips? #184
Soundguy said:
Your bucket trick reminded me of one that I do.
For caulk guns.. sometimes you can save a partial tube of caulk 2 ways.. screw a big screw into the tip end.. or put a big wire nut on it.
Soundguy
Save whats left in the cartridge by unscrewing the tip and putting some 'Glad wrap' over the hole. Then screw the tip back on.
   / Repair/mechanic tricks and or tips? #185
Pat, You may be a redneck if you dispense BBQ sauce with a caulking gun!!! Thanks for the idea. Greg.
   / Repair/mechanic tricks and or tips? #186
You may be a red neck if you stage competitions for distance and accuracy using compressed air to shoot the caulk tube pistons! They really get out there!
Pat
1. Take off old zerk. 2. Clean the area around the hole with a grinder. 3. Weld a 1/4-28 nut over the hole (a good mig welder does a nice job of this, TIP- screw a fine thread bolt through the nut before you weld, it will center the nut over the hole, and keep spatter off the threads.) 4. Once welded, install grease fitting, and grease while its still hot. This clears out any burnt grease, and makes it easier to grease in the future.
This was suggested by diyDave, I thought it was a nifty idea for a problem that a lot of folks here on TBN experience.
   / Repair/mechanic tricks and or tips? #188
PineRidge said:
I got tired always looking for ring pins that are used to secure implements in place. I finally took 2 single pieces of chain and bolted each to the folding PTO stub guard.
I have lost several of the BIG EXPENSIVE pins that secure the QuickAttach implements on the FEL. I welded chain to secure them. The chains broke bashing in rocks and gravel and brush and the big$ pins fell out. I welded on heavier chain. The locks disassembled themselves and the pins fell out. I will either weld really big chain or just use a bolt through the keeper holes and double nut them with nylocks.
Pat
   / Repair/mechanic tricks and or tips? #189
To aid pulling lower lift arms into place on implement pins use a cam lock motorcycle tie down to help pull arms together. You can get a 2 to 1 force as you pull the strap to tighten if you position the pull side appropriately. Incremental gains are kept, so you always are taking forward steps.
larry
   / Repair/mechanic tricks and or tips? #190
BTDT- Thanks for the props, but I learned it from Richard Gosheff, a local farmer who years ago led a little march on the mall in Washington, D.C.:D
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2010 L3V Electric cart (A51694)
2010 L3V Electric...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
100 FUEL TANK (A53843)
CAT 336 D, Cab, Heat/Air Excavator (A52384)
CAT 336 D, Cab...
1986 Nissan King Cab Pickup (A52384)
1986 Nissan King...
