Repair/mechanic tricks and or tips?
   / Repair/mechanic tricks and or tips? #61
This is great- I don't think I've ever read thru 6 pages of posts with so much fun. Here's my little trick, thanks to a working electrican: When pulling wires thru conduit (like when wiring a new shop from the house panel) you make a little ball using plastic bags and tape that just fits in the conduit- attach it to the pull string, and use a vacuum to suck it thru. Just make sure that any leftover fumes from the solvent are clear, or you can have a catastrophic failure of your vacuum motor- or so say those with more experience than me.
   / Repair/mechanic tricks and or tips? #62
varmint said:
... Just make sure that any leftover fumes from the solvent are clear, or you can have a catastrophic failure of your vacuum motor- or so say those with more experience than me.
Guess I am slow today. What solvent fumes?
   / Repair/mechanic tricks and or tips? #64
That works great in reverse to.. and safer.
In the audio industry, we 'blow strings' all the time. Generally we like to assemble chase pipes with strings in them.. occasionally a 'day labor' will pull the string leaving a naked chase.
Tat a big wad of string, make a ball of tape or plastic bag.. we call this a 'rat' shove the rat into the pipe and seat it in a few feet with a dowell.. insert enough loose string to make the run, and then retain the end on the outside of the pipe with gaff tape, then take a blow gun with a rubber tip ( rubber cork works great ), then give it 90-120 psi air. It makes space mountain look like a wimpy ride when the rat shoots out the other end of the pipe a mach 1...
Soundguy
   / Repair/mechanic tricks and or tips? #65
Cut a notch in a large flat screwdriver side to remove springs such as in an atv exhaust etc
Earplugs prevent slag and sparks from painfully entering your ears when welding and cutting.
ALAN
   / Repair/mechanic tricks and or tips? #66
I thgought that was what the welding helmet and beanie were for??
Soundguy
   / Repair/mechanic tricks and or tips? #67
Use your brush cutters/pruner to cut heavy wire. My cheap lopper cuts thru 000 like butter.
Oil your air tools after you use them, they'll always be ready for next time.
Install a Fumoto drain valve, you'll never go back to a standard drain plug.
Always remove the fill plug before you remove a drain plug, (rear diff's, tranny's etc).
Always torque your lug nuts.
Use neverseize/antiseize when you have 2 different metals in contact, (like alloy wheels and a steel brake rotor).
Use locktite on anything you don't want coming apart.
Lube the rails/slides on your brake calipers.
Open the bleeder before you compress the brake caliper.
Start with the 1/2" impact before you try the 1".
Impact, heat, leverage and air are your friends.
I've never broken a cheap wrench but I've upsized a couple of open end wrenches, (for example I have a 7/16's that is now a 1/2", that doesn't happen when you have a quality tool).
   / Repair/mechanic tricks and or tips? #68
Spray grease, such as motorbike chain lube is greal great for greasing tricky places, it come out liquid and sets after a short while into grease. While it is liquid it will run into small gaps.
   / Repair/mechanic tricks and or tips? #69
Two tips I haven't seen mentioned yet:
Coarse or medium grade valve grinding paste can be used to stop a screwdriver (any pattern) from slipping (yes, I know there is a commercial product, but I have valve grinding paste!). Also works astoundingly well on small rounded nuts! Remember to clean it off - it is an abrasive!
An arc welder can heat up stuck metal parts simply. Apply earth clamp to one side, torch end to other. Switch on, switch off (you need to check the heat - my little welder takes about 5 seconds of on time to heat most things enough). Freed a few hopelessly stuck ball joints this way - one tap with a hammer and it just falls out.
   / Repair/mechanic tricks and or tips? #70
if it aint broke, dont fix it.
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
(1) UNUSED 7000# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 7000#...
JOHN DEERE LOT NUMBER 19 (A53084)
JOHN DEERE LOT...
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
