Replacement Aerator Tines
   / Replacement Aerator Tines #1
Spiderman
Midlothian, Va.
Kubota L4630
I'm looking for a source for replacement tines for a 10+ year old Pacer aerator. My dealer says he can get them for $11 each but that seems pricey to me especially when there are 120 tines on the machine (although not all 120 need to be replaced). Do any of you know of another source for replacement aerator tines? Thnaks for your help.
   / Replacement Aerator Tines #2
That price isn't terrible. You should see what bush hog wants for theirs. Everything attachments has some that are petter priced. I don't kon if they will fit yours, but they fit my bush hog.
Thanks for your replies. The "Everything Attachment" tines won't work. The tines I need are 3/4" that straddle mount a 1/4" wheel and are anchored by 2 bolts 1 1/2" apart. I've tried contacting the manufacturer with no luck so far.
For those of you that may have a similar need R & R Products, Inc has these tines. Part #R301411
   / Replacement Aerator Tines #8
We have the Aerator tine. Our Boron Steel two hole tine is $4.25 freight included if you purchase $100 or more.
HayDR,
As noted in a previous post the tine that I need has a 1/4" slot to fit over a 1/4" wheel and the bolts are 1 1/2" apart. Unless I am mistaken, the diagram that you attached does not show either of these. Thanks for trying. Please post if you do have the correct tine
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55314)
Michelin CARGOXBIB...
130 BARREL TANKER (A55745)
130 BARREL TANKER...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
