replacement PTO shaft
/ replacement PTO shaft #1
buck12
Mississippi
Kubota 5460HSTC
I recently bought a used Mahindra 2615 that came with a Woods GT60 tiller. The tiller is much older than the tractor but works well. The PTO shaft is bent near the yoke at the tiller end of the shaft (the male part of the shaft). The shaft is held to the yoke by a roller pin. The shaft for lack of a better description is triangular. Where can I purchase just the shaft less the yoke? Or, am I better off taking the shaft to a machine shop and having it straightened? Thanks for any help.
/ replacement PTO shaft #2
getting it straightened is dicey at best... I'd opt for replacement. TSC has some shaft parts on the shelf.. is you'rs a "lemon" style?
soundguy
/ replacement PTO shaft #3
Agmaster shows a roughly triangular shaft they call a Trilobe. It's on the bottom of page 3:
  • Agmaster_Cat_DLS07_11.pdf
I think I found a local supplier that sells just the tube. Now if I can separate the yoke and the tube.
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2010 Unverferth 1225 Rolling Harrow (A63116)
2010 Unverferth...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
