Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld?
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Bought a 1970s boat trailer (with a boat on it) that has a coupler for a 1 7/8" ball. I am biased against 1 7/8" balls (I don't currently own one and I like it that way), so it will be upgraded to a 2" ball as soon as it gets home.
The trailer tongue is 2 1/2" box tubing with a 2 1/2" coupler welded onto it. The current coupler is 2 3/4" wide on the outside.
Should I completely remove the current coupler (grind off the welds and smooth things out after) and bolt a new 2 1/2" coupler on (with a weld to make sure it stays put), or should I cut off the ball part of the current coupler (so the coupler ends at the end of the box tube, roughly where the red line is in the picture below), add a pair of 1/8" shims to the sides and bolt on a new 3" coupler?
My thought on leaving it would be that it would give a little extra "meat" for the bolts to go through, but I am not sure it would be worth it.
Any thoughts?
Thanks
Aaron Z
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #2
Ive done that a few times before. For a long time the smallest coupler I had was a 2". When I got a trailer with 1 7/8" I'd usually unbolt and cut it off if welded, then weld shims on each side of the tubing so the new coupler fit snugly. Then clamp the new coupler in place and drill new holes through the shim plates. Once the new coupler was bolted on I'd add a few welds.
The problem with cutting the existing coupler and placing the new coupler over it is that the bolt holes won't line up.
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #3
If it was me, I'd remove the old one completely and weld the new one on with no bolts if possible. Last time I had one welded on, the shop welded the back edge, the lower edges along the sides, and through the bolt holes. There were no bolts (before or after). I think drilling bolt holes through the tongue tubing can only weaken things.
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #4
I see the bolt on used for both size hitches. The main reason is most people can run a drill. More people would weld them in addition to bolting if more people had welders. I was told at one time that Ohio required bolts to be used when installing a trailer hitch to a tow vehicle. Did not know if it was true or not. My car trailer has worn the 2 inch ball coupler pretty thin in the last 35 years and it is going to get the cap and shim replacement.
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #5
Get some bait, unload the boat, go fishin', forget about the trailer ;)
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #6
Although I like to weld almost everything I bolt on this type of trailer hitch. If it some how gets bent, it's very easy to change as compared to one that is welded on.
Al
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #7
I would not cut the coupler.
Chris
   / Replacing a trailer coupler, shim and go up a size, or grind off, bolt and reweld? #9
Why would you want to go with a 3" coupler? I hate 1 7/8" balls too. I have one but the tongue is 2" square tube. The best I could find in a 2" ball was a 2 1/2". So after taking a 4 1/2" grinder with a cutoff wheel I used a couple of washers for spacers. I debated putting a bolt through one of the holes in the top of the couple but didn't have one short enough not to hit the bolt going across so I just welded both of the top holes and the top edge of the coupler to the tube. I would think the only reason to go with a 3" coupler would be for towing capacity. Usually any trailer with a 1 7/8" ball isn't going to be hauling much weight though.
Edit: I did put two pieces of pipe inside the tube so I could tighten down the cross bolts without fear of collapsing the tube.
My only thought was that going over the existing (welded on) coupler would give a little more meat for the bolts to grab onto.
The existing coupler is 2 3/4" wide, so I would need a coupler sized for 3" tubing and a 2" ball.
Aaron Z
Dumpster Canister (A44571)
Dumpster Canister...
2012 FREIGHTLINER M2 STAKE BED 24’ LENGTH (A43004)
2012 FREIGHTLINER...
2010 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A43004)
2010 FREIGHTLINER...
New/Unused 2025 MX15RX Mini Excavator (A44391)
New/Unused 2025...
2014 International DuraStar 4300 2,500 Gallon Water Truck (A44571)
2014 International...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
