replacing worn disks
/ replacing worn disks #1
spo307
Levittown & Long Eddy NY
kubota L4400
I am refurbishing the jd kba disk I picked up. I took it apart and noticed the 3 inner disks ( front and rear gangs ) are severely worn.
1. do i have to replace all the disks or can I just replace the worn down ones?
2. is this wear from a miss alignment, or normal wear? thanks
KEN IS THERE AN ADVANTAGE IF I MADE THE REAR BLADES NOTCHED, OR SHOULD I KEEP THEM SMOOTH.
IF I MADE THE BLADES 16" INSTEAD OR 18"?
AND IS 3.5MM THICKNESS GOOD ENOUGH OR SHOULD I ORDER 4.5MM. LASTLEY DO YOU HAVE HANGERS AND SCRAPER BLADES?
THANKS DENNIS
/ replacing worn disks #7
THANKS DENNIS
If you have rocks, go with thicker bladee. Notched is more agressive, however, they dont last as long as smooth. Most like notched on the front and smooth on the back.
There are 4 different casting #'s for the hangers for the scrappers. Let us know the casting # you need and Qty and we will see what we can find. We have a very few scrapper blades. Ken Sweet
/ replacing worn disks #10
i would think they would fit thats only a few mm per axle, your nut wont screw on as for i would think, but thats it.
/ replacing worn disks #13
How many blades on each gang? Ken Sweet
I went back and counted 7 blades per gang. If you go with blades that are 1 MM thicker than what is on there, you will use up about a extra 1/4 inch of your threads on the axle. No big deal. Ken Sweet
ok went with 20" 4.5mm, they fit and man are they big, I have enough thread for a slotted nut, have to drill the holes and install the cotter pins, almost finished with the refurb. thanks for the help.
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
213130 (A64276)
213130 (A64276)
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
20ft 4-Door Shipping Container with Shelving (A61572)
20ft 4-Door...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
26ft. Truck Box Body (A61573)
26ft. Truck Box...
