AKKAMAAN
Veteran Member
How do we use the control valves and restrictions to control cylinder speed in an Open Center, OC, system (Constant Flow, CF) and a Closed Center, CC, system (Constant Pressure, CP)???
Yay, i need to bone up on my hydraulics knowledge.
Since you say 'or', I'm assuming it's one or the other, not both.
With that in mind, I'd say you have to put the valve at Y for the open center system, otherwise you could not build a working pressure.
For a closed center system with constant pressure, I'd guess the valve would have to be at X to (not sure what the technical term here would be) block pressure to the cylinder.
It seems that the 'real world' is more complex, because open center systems will always have some pressure just to maintain constant flow through the circuit. So i'd guess that open center does both X and Y in reality. Closed center seems like it could get by with just X...not sure.
Does one have to be plumbed in series and one in parallel if there are multiple cylinders? I would guess open center is series and closed is parallel.
Are we asking still, or pointing out??
Seems to me cylinder will start moving as soon as flow restricts enough to build pressure greater then load as soon as A is closing and B is opening.
Did you mean check valve D instead of C ???
If you did then, check valve C will hold load on cylinder untill pressure from A port closing off is more then load.
