Retorquing wheels
   / Retorquing wheels #101
There's no doubt a paint line is a good system Roy. What do you reckon to those pointy things that sit on the wheel nuts and tell the story from the 25 yard line please?
Mike
I'm not sure what you meant by that question...
BTW, don't give me credit for the torque striping. That's been used in industry for decades.
   / Retorquing wheels #102
Apparently those "those pointy things that sit on the wheel nuts and tell the story from the 25 yard line please?" are called wheel nut pointers Roy.
I was kinda endorsing the idea of torque striping,
Mike
   / Retorquing wheels #103
Mike
I did a Google search...so now I know what they are. Apparently pretty common in the UK and other areas of the (former) British Empire.
I've never seen them in the US though (maybe that means I don't get out much!).
   / Retorquing wheels #104
   / Retorquing wheels #105
Bottom Line.........Is 'Torque' really that critical when installing (steel) Tractor Wheels? I've removed and replaced them many times just by 'feel'! I've also replaced the heads on my old VW Diesel, and was quite sensitive to 'torquing' in 'stages, and sequence', using new (unstreched bolts)! Guess I can understand it on Aluminum wheels and (if I ever had a BMW) torquing disc brakes. But Steel Tractor Wheels?..........I think we're overthinking this...........~Scotty
   / Retorquing wheels #106
~Scotty
Yeah, I think so too...the main thing is to ensure they aren't loosening on you.
   / Retorquing wheels #107
I hope I haven't tricked you into over thinking Scotty.
As you don't have any problems, then the information I've offered you ain't worth a jot.
If you ever have problems, which I hope you don't, then, I hope some of it will help you to solve those problems.
If I can add a postscript to your comment please Roy, I'd like to add 'and as long as you can get them off again without too much grunting', I think that in your case Scotty, we are, as you put it, over talking things.
Kind Regards, Mike
   / Retorquing wheels #108
BOLT TORQUE FACTORS
LUBRICANT OR PLATING
TORQUE CHANGES
Oil Reduce torque 15% to 25%
Dry Film (Teflon or moly based) Reduce torque 50%
Dry Wax (Cetyl alcohol) Reduce torque 50%
Chrome plating No change
Cadmium plating Reduce torque 25%
Zinc plating Reduce torque 15%
BOLTS AND TORQUE SPECS
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
