Revised Ohio Commercial Vehicle Rules
   / Revised Ohio Commercial Vehicle Rules #11
New Safety Rules for Private Intrastate Non-CDL Vehicles - PUCO
Individuals transporting personal items are still not be subject to these safety rules.
But also this is one of the 'safety rules' Private motor carriers transporting hazardous materials are required to maintain insurance. Automobiles, machinery and equipment with combustible engines are considered hazardous materials. Refer to Ohio Administrative Code section 4901:2-13-02 for the complete insurance requirements. WTF over?
So I guess I can expect to get harassed just because they need $$$$.
Chad
   / Revised Ohio Commercial Vehicle Rules #12
It refers to "not for hire". I believe that is a specific classification, e.g. commercial use within a company but not for outside hire. Note also it says "Please note: If a vehicle crosses state lines, a USDOT number must also be visible on the vehicle." I think that is also an indication of the scope.
Ken
Chad
   / Revised Ohio Commercial Vehicle Rules #13
Looks like another revenue source to me.
I have a dually diesel with a 30' tandem dually gooseneck lowboy trailer......think I'll get stopped somewhere in the future?!:thumbsup:
   / Revised Ohio Commercial Vehicle Rules #14
When the Federal CMV came into existence about 20 years ago, it slightly changed what was commercial from what it had been in the past.
The result, because of licensing requirements many FORMER CMV owners have transitioned to P/U based vehicles + GN trailers to CIRCUMVENT being labeled a "commercial" vehicle (CMV).
I was not as involved as deeply in the industry well BEFORE the CDL/CMV changes as I became after/during the change, but it was always my understanding that if you were "For Hire" you needed a DOT# and "authority", they just looked the other way most of the time. We got caught in this, I told the owner we needed to letter our units with the DOT#s, City and state but he refused. We received nice fines on each unit to show for it too!
Now that the country has grown and the CMV/CDL rules of the early '90s have affected a major shift in how vehicles are used and by whom, the sheer numbers of those operating ILLEGALLY and UNSAFELY has grown to be a big problem.
This has been discussed many times before and I of course, do not have all the answers, but I am also not a lobbyist trying to gut necessary regulation or impose undue hardships. I believe the laws should generally be as follows (I believe I have logical and reasonable justifications for each):
CMV:
1) Any vehicle owned, leased, rented, or borrowed and used to further a business enterprise operated by a person other than the registered owner or immediate family member (parent/self/child). Not limited to powered units, (specifically excludes any vehicle owned by and used soley to transport family members "not for hire").
2) Any vehicle designed or built to transport passengers having a total capacity of 9 or greater persons, or any capacity if for compensation.
3) Any "combination vehicle" used to further a business enterprise (specifically INcludes: all towing or towed units and combinations regardless of GVW or GCVW rating(s) or vehicle type).
4) Any vehicle used to transport persons who are not related to the operator to or from school or on a school related/sponsored activity except by emergency.
5) Any vehicle identified as a type of "Bus" by VIN, design, construction, intended use, actual use, outward identification or FMVSS tag.
Safety:
1) All CMVs must undergo an annual safety inspection.
2) Must conform to Apdx "G"
3) Must supply evidence of current insurance meeting statutory minimums covering all units if a combination.
4) Cannot "self inspect" unless in the business of vehicle repair (as advertised) and can only inspect vehicle types consistent with their normal business activities.
5) Inspectors must be certified both by "ASE" and the Sate/Federal program for the vehicle types and systems they inspect.
6) Re-inspection fees apply only if: a) The vehicle(s) is/are removed from the premises of the inspecting facility for longer than 7 calendar days, b) The inspection(s) from the prior year has expired before the vehicle(s) is/are re-inspected, or c) The vehicle(s) are not re-inspected at the same inspecting facility as conducted the initial inspection.
7) In a combination, each towed unit(s) must have brakes meeting "Apdx G" requirements on all installed axles in the proportional amount that exceeds the towing vehicle's GVW.
8) "GCVW" will not be considered in any weight calculation.
CDL/DL:
1) A "CDL" is required to operate any "CMV", must pass "Road Test" in vehicle type applied for.
2) A "type test" is required to operate any vehicle other than: Single unit motor vehicle having at least three but no more than 6 tires (ie: Car, pickup, van) under 10,000lbs GVW and not used to further business interests (non-CDL requirements, but type test still required as appropriate for vehicle type).
2a) Motorcycle = type test required (M + RT)
2b) Bus, regardless of capacity or intended use = (P)
2c) Medium Motor Vehicle, any single unit MV regardless of design or intended use over 10,000lbs GVW = (B), (B+Air+RT if CDL)
2d) Combination, any motor vehicle used to tow another unit where the [towing unit GVW + towed unit GVW (actual, as measured)] is greater than the [towing vehicle GCVW] or 10,000lbs whichever is LOWER = (A+Air+RT for all)
2e) RV, any motor vehicle or towed unit designed, built, registered as an "RV" (having all of: interior toilet, refrigerator, heating system not requiring the running of an internal combustion engine) = (RVA or RVB, with Air if equiped - not a "CDL" license and does not require a road test).
3) Farm = DL with all appropriate type endorsements, does NOT need to meet CDL requirements (health card, background etc if vehicle is owned by self or immediate family AND used to transport owned, rented or leased farm related materials including animals).
3a) Farm employees must comply with CDL requirements.
The general theory of the above is: If you are operating a vehicle IN COMMERCE, you need the appropriate CDL. If you are driving something you are not trained on (non automobile), you need some basic knowledge on it. Whatever you are driving in commerce needs to be SAFE enough to operate. If you are a farmer, we won't break you, but relaxed rules apply to you as well.
   / Revised Ohio Commercial Vehicle Rules #15
I found this for Texas. I have had people argue with me and say the flow chart is inaccurate. It comes from Texas Department of Public Transportation (troopers). I called them and they told me the flow chart was accurate but i am calling them again because supposedly they are ticketing trailers over 10k even if the GCWR for truck and trailer combo is under 26k but that's only what I have been told.
TxDPS - CVE Commercial Driver License Classifications
Anyway, try this out and see what it says.
   / Revised Ohio Commercial Vehicle Rules #16
Under current FEDERAL laws, you are OK with a 10K+ trailer if the GCVW is under 26k as you stated, but ONLY if used soley for inTRAstate commerce, the moment you cross state lines inTERstate), that trailer being over 10K places the vehicle into the CDL/CMV catagory.
   / Revised Ohio Commercial Vehicle Rules #17
Under current FEDERAL laws, you are OK with a 10K+ trailer if the GCVW is under 26k as you stated, but ONLY if used soley for inTRAstate commerce, the moment you cross state lines inTERstate), that trailer being over 10K places the vehicle into the CDL catagory.
Incorrect.
The combined GVWR has to be over 26k to make it a CMV requiring a CDL.
NO.
RV is exempt.
Do you pull trailer for your business? IF your GVWR or combined GVWR is 10k or under then you are not a CMV-Commercial Motor Vehicle.
Trailers are pulled by both trucks for personally owned rental/rehab properties. The trucks are not driven by employees.
This has definatally caught my eye.
I am not too knowledged on this whole subject. But their seems to be several threads each year come up about trailering and what is leagal and what is not. And no one ever seems to have a clear cut answer.
I have a 1/2 ton silverado, 6600GVWR. I also have a 7k trailer to pull around the tractor and other things. Trailer is NON COMM. BUT I do have COMM plates on the truck for plowing purposes.
And since you cant just run COM plats part of the year, in the summer when I am trailering the tractor to/from my house to where we cut wood, am I now illegal??????? Will I have to have a CDL???Medical exams???
From what I read the medical exam, safety equipment, logs and the inspections will be required if you exceed 10K.
What I am not sure is what the requirements are if you are using the commercially plated vehicle (less than 10K) for personal towing.
   / Revised Ohio Commercial Vehicle Rules #20
Incorrect.
Incorrect, FEDERAL is any vehicle with a towed unit that is over 10K that crosses state lines OR a 26,001 GVW (license, rated, actual) unit with or w/o towed unit.
Laws very by STATE that may say the total GVW of both needs to be over 26K, I know MN is this way, but Federal is anything in commerce with a towed unit over 10K crossing state lines.
2021 BOBCAT T870 SKID STEER (A52709)
2021 BOBCAT T870...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A55973)
2014 International...
