Rhino HPHD
   / Rhino HPHD #1
bake321
Kentucky
Kubota 9540, Kubota RTV900
I bought a new post hole digger and sure am going through shear pins/bolts. The grade two that came with it were a real joke, they advertize a five year gear box warrenty, well with those bolts it would last forever. I went with grade five and even with the RPMs low and babying the dig, I,m still going through pins. The ground has a lot of rock, but is quite moist. Anyone else ran into this?
Bake
   / Rhino HPHD #2
Bake
I have one, use it in sandy-loam-clay no problem, so I can't compare to your situation. Good news you have plenty of torque.
   / Rhino HPHD #3
I'm running a Rhino SPHD in the limestone and clay in our part of KY. It uses custom stepped shear pins in the driveline--different than yours?. Haven't broken one in 3 years. I do cut just a few inches at a time, clear the waste, take a few more inches...
   / Rhino HPHD #4
I bought a Fleet farm PHD that has shear pins for the safty feature. When I hit a big rock it pops them but handles anything softball size and down with no problems.
   / Rhino HPHD
Well it went better today, I added more patience, I also found that if I didn't clear the hole as often it did a better job of bringing the rocks out of the hole. I used a Danuser before this with modifications which I think taught me some bad habits. The old girl bit the dust hooked to this new tractor. Foodplot the shear pins on this unit are 3/8ths by 3 inch bolts. Your unit is heavier than this one from what I gather from Rhinos site which dosen't say much. I'm east of Scottsville.
Bake
   / Rhino HPHD
Bill good point "Good news you have plenty of torque". I went from a 1965 Allis Chalmers D10 1965 with 20 some pto hp to a 2007 Kubota M9540 with 84 pto hp.;) I better learn to hold the big girl back
Bake
   / Rhino HPHD #7
Yep, You've likely got nearly as much power at idle with the Kubota as you did at full throttle with the old AC. Those shear pins are on there for a reason! ;)
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
VOLVO EC350EL EXCAVATOR (A60429)
VOLVO EC350EL...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2003 Big Tex 10PI...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
