Riding mower deck wash port installed in 10 minutes
   / Riding mower deck wash port installed in 10 minutes #1
jkk04
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Installed a deck wash port purchased from Amazon.
Needed a 5/8" drill bit and 24mm wrench socket for drilling the hole and tightening up.
It took less than 10 minutes.
It makes easy cleaning the deck
Jkk
   / Riding mower deck wash port installed in 10 minutes #2
My mower deck had one when it was new 10 years ago. I tried it out after mowing and it made a huge mess in the yard beside the house. I spent 30 minutes raking it up, shoveling it into a wheelbarrow and dumping it at the side of the field. Then
I spent 10 minutes taking it off and plugging the hole with a shinny carriage bolt.
   / Riding mower deck wash port installed in 10 minutes #3
Sounds like it did it’s job cleaning out your mowing deck.
   / Riding mower deck wash port installed in 10 minutes #4
Actually, no it didn't, it blew off less than half of the clippings. All it did was make everything wet. The deck still had a lot of wet grass stuck to it. The next day, the garage floor was grass stained and the garage smelled like fermenting grass for 2 days.
   / Riding mower deck wash port installed in 10 minutes #7
All that deck wash gimmick does is destroy your spindle bearings. Have it on both my zero turns. never use it.
and I have used it for 15 years at this point for every single mowing, original spindles. 0 grass.
   / Riding mower deck wash port installed in 10 minutes #8
I have had a three older Deere riders.They didn't have wash ports. I would put them on car ramps or something to lift them up so I could hose them and putty knife them well. Most often after every use. Caked up mud and dirt are the culprits. When HF started selling different mower lifts, it was a gift from heaven. IMHO there is no replacement for hands-on investigative cleaning of the deck to keep the mower running right, cutting right.
Last year I bought a new X370 with the wash out port. yeah it works, but not as good as getting under it with the putty knife and or hose. My dad was a stickler for cleaning all his moving equipment. It looked sharp and was lots easier to pull maintenance on a clean machine. I took a gig once with a county parks department. We hosed everything down every day. It paid in dividends. Hose under neath and on top, got the stuff CLEANNNNN.
   / Riding mower deck wash port installed in 10 minutes #9
I have never used one of these..nor have I ever had a deck rust out.
My current mower is a lower end bobcat and when ever I remove the blades I hardly see anything to even scrape off. Maybe it's the deck shape and blade tip speed?
   / Riding mower deck wash port installed in 10 minutes #10
My JD X570 has a wash port. Tried it once - didn't do squat. Too much dirt combined with the grass clippings. Too many pocket gopher mounds.
I have dozens of chipper clipping mounds. I drive the mower up on top of a mound - lower the cutter deck - activate the blades - let the chipper clippings clean the underside of the deck. Works like a champ.
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A55787)
2017 Bomag BW90...
2018 SKYJACK SJIII3219 ELECTRIC SCISSOR LIFT (A52705)
2018 SKYJACK...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2011 Ford F-250 Crew Cab 4X4 Pickup Truck (A55788)
2011 Ford F-250...
