Right Angle Gearbox Needed
   / Right Angle Gearbox Needed
Dave, What diameter shafting are you going to use from the gearbox to the sidecover and then thru the roller? Please post some pictures when you start. Thanks
Right now I'm thinking 1 3/8" shafting from the Gearbox -> Sidecover
I will post pics when I'm at that point...just getting my ducks in a row so during mud season when I'm done blowing snow, yet the ground is too messy to work with, I got something to do.
   / Right Angle Gearbox Needed #22
I'm locking to make a powered pto garden tiller 60'' what gearbox do I need?
   / Right Angle Gearbox Needed #23
How about using a differential drill out some sprockets bolt on the wheel lugs and sprocket it down to the shaft with the tines on it, run the differential with the pto shaft,
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2020 PETERBILT 567 TRIAXLE (INOPERABLE) (A52472)
2020 PETERBILT 567...
