rim guard, anti-freeze, or ww fluid
   / rim guard, anti-freeze, or ww fluid #21
I looked at the MSDS on WW fluid and I can't get the link to work.
If you go to this address and just give an e-mail address you can search for MSDS sheets (material saftey data sheet) MSDS sheets
Well, I decided to use automotive antifreeze. It was not to difficult to get used stuff for free and upon testing, it was good for -40 so put it in tonight. All I got was 12 gallons or so and the tire seemed to take almost all of it, I would say about 11 gallons or better. I used the TSC adapter and a drill pump. It took me about 1 1/2 hours with set up to fill one tire. The drill pump I have is difficult to get primed and very slow once it starts. I am going to look for a better one and do the other side as soon as I find more AF. Any one know of a good drill pump and where to get it? Also, my drill is only 550 rpm, is that the issue? /forums/images/graemlins/confused.gif
   / rim guard, anti-freeze, or ww fluid #23
</font><font color="blue" class="small">( Well, I decided to use automotive antifreeze. )</font>
Bear in mind you picked a very toxic solution. 1 teaspoon of anti-freeze will kill a large dog or a child. The same amount will make an adult very ill and without very fast treatment likely would induce a coma. Automotive anti-freeze is sweet smelling, very attractive to animals and children. Should you ever spring a leak, even a small one, you may have a very serious issue and a very dangerous mess.
   / rim guard, anti-freeze, or ww fluid #24
I got a cheap Under $20 boat bilge pump (12V)from Wmart when I loaded the 870 tires with WW fluid. Dropped pump in a five gal. bucket and kept it full dumping gallon at a time. Took under half hour per tire as I recall. Had to stop periodically to bleed air off. To speak to another area, after a couple of years I cleaned off a valve stem while plowing and had to remove fluid to replace the tube. The rim looked fine, that is, no corrosion was evident. I refilled it and as far as I know it is still fine. 11.2x24 R1 took around 30 gal/tire over the top of the rim.
</font><font color="blue" class="small">( I got a cheap Under $20 boat bilge pump (12V)from Wmart when I loaded the 870 tires with WW fluid. Dropped pump in a five gal. bucket and kept it full dumping gallon at a time. Took under half hour per tire as I recall. Had to stop periodically to bleed air off. To speak to another area, after a couple of years I cleaned off a valve stem while plowing and had to remove fluid to replace the tube. The rim looked fine, that is, no corrosion was evident. I refilled it and as far as I know it is still fine. 11.2x24 R1 took around 30 gal/tire over the top of the rim. )</font>
I was wondering if one of those would work! I was afraid of burning up the motor as I didn't think they would pump much pressure against resistance. I also see as I look at specs on the net (I don't have the packaging or paperwork on my little pump), that the min recommended rpm is around 1200 and ideal would be 2000-3000 rpm. My drill is probably too slow.
I tried a different drill today that goes up to 3000 rpm. I ran it around 2000 and it was excellent. The pump primed itself nicely and seemed to pump faster also. Took less than 3 min. per gallon, including stopping to bleed air a couple times.
Oh, with my drill pump, I don't need to bleed the air at the valve. I just stop pumping and within a few seconds, the air will push back through the pump and the tire will bleed off the air pressure.
)</font>
hmmmm.... maybe I should leave a bowl out for the cats....hehe....JK /forums/images/graemlins/grin.gif
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2012 Club Car Precedent Electric Golf Cart (A55758)
2012 Club Car...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
Houle 48-6D-5250 Manure Tanker (A50775)
Houle 48-6D-5250...
SDLL50 Loader 36" GP Bucket, Quick Attach, Gas Engine, 6" Rubber Tracks, Aux Hydraulics, Hours: 0 (A47477)
SDLL50 Loader 36"...
