rippers
   / rippers #1
Solo
Platinum Member
Fairmont,WV
New Holland Boomer2030
I'm looking for a good heavy duty ripper to use for removing small tree stumps, something to use on my TC18. JD has a sub-soiler the B22, I believe, that looks pretty solid. Fred Cain also has a ripper that looks pretty solid. Any one have any info. on these or other models? Thanks in advance.
Solo
   / rippers #2
How big are the stumps you're talking about? I think you'll find stumps aren't so easy to rip out with a compact. You tend to spin your tires a lot more than than actually pulling out the stump! If you plan on using a single tooth ripper/sub soiler to drive around the base and rip through the roots before trying to pull you might have some success depending on the type of tree.
   / rippers
gerard
I call them trees, but actually there thorn apple bushes. Most are only 2"-3" in dia.. I don't think they will be a problem. Some of these I have taken out using only a mattock.
Solo
   / rippers #4
I don't know if you've seen this yet but someone made a mini version of the "brush brute" to fit on a three point instead of the bucket. If I had a lot of brush to clear this would be a must. Looks like it would do what you want really easily
   / rippers
gerard
Thanks for the info. It really does'nt look that hard to make.
Solo
   / rippers #6
Is that thing a tool, attachment, or weapon. Looks like something out of the middle ages. Mighty oaks would jump clean out of the ground at the sight of that thing. /w3tcompact/icons/laugh.gif
   / rippers #7
Gerard,
Can you re-post the picture - for some reason I don't see it when I view the attachment.
Patrick
   / rippers #8
Looks like the link to the photo is broken.
   / rippers #9
Hmm . . ., it works for me. Reckon that's because I'd looked at it before and it's in a cookie or some other such computer thing that I don't understand?/w3tcompact/icons/blush.gif
   / rippers #10
It may be cached on your hard drive somewherem - that often happens. I just tried it again and still no luck though. Since it is a forum file for TBN and not an external web-site I'm guessing that it was deleted somehow.
Patrick
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
New/Unused Forklift Jib (A51573)
New/Unused...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
