Road and Driveway maintenance
   / Road and Driveway maintenance
Diesel-ME said:
KC,
I went with a Woods LR108-2 with blade and wheels. Based on pricing on the 108 ($1700 out the door), I'd guess that a model 106 (the right size the the tractor size that you mentioned) would run you $1400-ish...??...just call a few dealers. They probably have $150-$200 to negotiate with on the final price BTW.
Land Pride also makes some very similar stuff. I checked a few local dealers and found that Land Pride seems to run a for more $$s for some reason. Looks like they make nice stuff though. You would probably want an LR15 Series rake.
The only real draw back of the rake/blade is that you are not going to be able to cut down through hard packed gravel to completely eliminate rough areas like you can with a box w/ scarifiers. But for a smallish tractor I would think that you could drag a much wider rake/blade, say 72" than you could a box. Folks who I know that have 20-something HP tractors usually have 48" box scrapers - but I'm no expert about sizing in this case. The dealers will usually give you an honest assessment of the right fit for your needs.
~paul
Paul, I see your in Maine, how is the blade moving snow?
KC
   / Road and Driveway maintenance #42
KC
Don't know and won't find out - have a 96" hydraulic QA snow plow :)
But do note, that the flip down blades that mount on rakes are only 5-7" high whereas the purpose built rear blades are usually 12-19" in height. In any case I'd rather not find out how a rear blade would move 30" of snow.
~paul
~paul
THanks, when I get down the tractor purchase I will know how much I can spend on attachments.
KC
206320 (A57192)
206320 (A57192)
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
Blast Off Hot Pressure Washer Trailer (A59228)
Blast Off Hot...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
