SamWalton
Platinum Member
We just put in a 2600' road with 6" of gravel run 12' wide in north texas (about 30 miles south of the Red River). We had all the gravel delivered when gas was at the peak, Sept 08, wish I would have done it now. The price for all the gravel was 10k. $90 per hour seems about right. Will he use a dozer or a motor grader? If he is a good operate he can do it well with a dozer but a motor grader can cut a perfect line.
One thing we did; was make sure that the base (dirt) sat from a long time almost 1 year. I cut away around 4" of top soil and brough in new clean soil and spread. Once this soil was compacted for almost a year we could get an idea of where the water was causing problems before we put down the road gravel. Not removing the grass and not crowning the road correctly will make any gravel road fail. You need to make sure that all the water will shed away from the road and not pool on the road base, and that there is not organic matter growing or in the dirt. I will post some pics later.
I am not sure about the equpment they were planning on using most likley a dozer and I can't wait for the ground to settle.
