Road maintenance - Tuffline v. Grademaster v. Roadboss
   / Road maintenance - Tuffline v. Grademaster v. Roadboss
Mtnview, that makes sense. You don't think things would spill out the top of the box the same way though?
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #92
Charles, they would, sort of. But it's going to take one heck of a machine to have spoils falling over a 24" tall blade vs like they do over a 6" blade. :laughing: A box blade curls the material forward and tries to contain it, while the road grader type blades cut and lift the material up and over the cutting edge to the rear trying to spill over and spread out.
Because of their different designs, typically a box blade seems like it stops cutting once it is over filled and just rides across the top of the ground not really gaining any more material. The grader blade continually cuts material, does not really load up and stop cutting. This has been my experience anyway, and of course ground conditions, moisture content etc. can make a big difference on how implements perform. ;)
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #93
Brian,
RG Manufacturing (the mfr of Road Boss) mentioned that the dealer in Texas has been quite ill.
I contacted RGM directly and they put me in touch with the dealer that delivered mine (same process, they deliver and you try it before you buy it.)
RFB
I am sad to hear this. He is a nice man and very knowledgeable person. I talked with him a couple of times at the Tulare World Ag Expo. He is the one that was able to tell me that I had Road Master grader blades, an out of business manufacturer that made the closest grader blade to his that there was.
I see what you mean about the box blade. hmmm.
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #95
Well, here's my new grader, i finally finished it. Works great :thumbsup:
Just before painting:
Assembled...
The road before...
Work in progress...
...and after...
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #96
Nice work on the landlplane good looking welds too. Curious how is the blade set in relationship to the bottom of the skids?
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #97
Well, if you mean the working depth; I made it adjustable :). That way I can use the cutting edges max. This picture should help...
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #98
Very nicely done... replaceable cutting edge, too. :)
   / Road maintenance - Tuffline v. Grademaster v. Roadboss #99
Yes, reversible and replaceable cutting edges. They are made of Hardox 500 so they should be extra durable...I hope...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2018 RoGator RG1100C Sprayer (A53342)
2018 RoGator...
2014 INTERNATIONAL MA025 BOX TRUCK (A52576)
2014 INTERNATIONAL...
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
