rocks and stumps
   / rocks and stumps #21
The old car hood as mentioned above works great - I have dragged rocks using this technique that would NOT drag on their own - it significantly reduces the resistance.
   / rocks and stumps #22
Ditto or the car hood. Great cheap implement.
Then there's the issue of getting that big stump or boulder dug out but can't get it out of the hole :(. Put a bucket of the dirt you dug out BACK INTO THE HOLE. Now rock the boulder/stump back and forth with the FEL or BH. Add another scoop of dirt and rock again. Bit by bit the large object will raise out of the hole as the loose dirt fills in below it when you rock it. Soon (or eventually) you will get it up high enough to roll or skid away. :D:D
   / rocks and stumps
i remember my father using a tool called a "johnson bar" . i swear he could move a truck box with that thing, along with a few steel pipes as rollers. i got the rock out of its hole using a long steel pipe. amazing what those things can do. gotta find a hood to drag it though. thanks again
steve
mass
   / rocks and stumps #24
Pallet forks work great. Here's one a dug up today. I was able to drag it out of the hole with backhoe. Then I was able to get the forks under it.
   / rocks and stumps #25
thanks for all the advise. i like the idea of the stone boat, will look into it. being a car guy all my life i was alittle leary about getting the tractor all scratched up. do you guy's still cringe when you hear that loud scrape?
steve
mass
Only if it's coming from other than the bucket.:eek:
   / rocks and stumps #26
Some of the BXs are now showing up with Kubota OEM skid plates. If yours doesn't have one, you can get your dealer to order it.
*It's inexpensive at $35, but doesn't seem too robust and won't protect from a punctured HST filter.
You can read about the new fan protector here: http://www.tractorbynet.com/forums/kubota-owning-operating/155254-kubota-should-just-do-right.html
You can buy true mid/rear and front skid plates here: Bro-Tek: Tractor Add Ons
But it should be a standar feature of the new BXs.
   / rocks and stumps #27
One more vote for the old car hood. I keep one around, out of sight, for that very reason.
Dan.
   / rocks and stumps #28
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Rhino 484 (A50322)
Rhino 484 (A50322)
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2004 Ford F250 (A50515)
2004 Ford F250...
UNUSED FUTURE 40" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 40"...
