Canopy Roll cage & new steel roof for my DK40SE
   / Roll cage & new steel roof for my DK40SE #31
I really need to do a belly pan. .
I managed to disable my 4wd again this weekend while driving over brush. Same issue as last time which is a simple disconnection of vulnerable electrics under the operator station floor. Took only a couple seconds to fix now that I know where to check but it does point out again the need to put some brush guard armor under there.
   / Roll cage & new steel roof for my DK40SE #32
Ha! I think the most complicated electronic gizmo on my tractor is the headlight! : )
1" plate??? good lord
:laughing:
   / Roll cage & new steel roof for my DK40SE #34
Hey, I need something to counter ballance the cage!
Update:
I kept getting a serious rattle from 1600-2000 rpm from the front support tubes where they bolt to the loader arm brace. I drilled a hole, then welded a nut to make a "set screw". Once tightened up, it fixed 90% of the rattle...so now it only vibrates at 1900 rpm, so I just stay out of that "zone".
Oh, and my cheapy Pyle radio would not play MP3 format off of Media Player, so I bought another radio from WallyWorld for $70 & it works perfect. The Pyle will go into the pontoon boat where we just listen to FM. To be honest I think a $40 MP3 player & headset is probably the better route. While operating at high RPM's I can't hear the radio unless I wear earpulgs(which I do anyway), so an MP3 would block engine noise while delivering a much better quality music. It is nice to have the speakers when at idle/low rpm, or when parked working on something in the field.
   / Roll cage & new steel roof for my DK40SE #36
Why not get one of the headphone sets with an i-pod/MP3 plug built in? I have one with AM/FM radio AND an i-pod plug all in one with digital display. Worktunes or some similar name, AO Safety is mfg, I believe. Link below: note ACE is selling them for $40 and so is Sears. I probably spent closer to $60 when I got mine- $40 is a good price IMHO.
AO Safety 90541-80000 Noise Reducing Headphones with AM/FM Radio
I thought about that CM, but when it's hovering around a hundered degrees those things will set my ears on fire.......:>o
I just got a set of "in the ear" plugs to use when riding my Motor, so for tractor work they would be fine too.
   / Roll cage & new steel roof for my DK40SE #38
MotorSeven, I've been thinking along the same line. 250+ for 8 dollars worth of plastic doesn't seem like a good deal. Could you tell us what the diamond plate cost? .perhaps before and after the rollI. I was also thinking 72" for some shade on the backhoe driver
Ron
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
2023 Utility Cargo Trailer (A51572)
2023 Utility Cargo...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
