Roll over box blade: who has one?
   / Roll over box blade: who has one? #11
Mine has replaceable cutting edges; doesn't your cutting edge bolt on?
It was pretty easy to cut the end plate off, rotate the pieces into position, and weld it back in place. Since then, all has worked fine. I have since then though, stopped trying to force my little 19hp tractor to do harder jobs... It's actually the forerunner to the B2710/2910 Kubota. It just has a smaller motor(mine is a B8200HST. B9200 had more like 24hp).
Maybe your could be repaired?
   / Roll over box blade: who has one? #12
RobertN, I like to have better control of the dirt when backfilling, and to drag and smooth out an area after scraping (with the drag in the back fill position). Also to put the rippers down and go. Don't worry about gathering dirt while ripping.
To be honest though, I was raised with a Gannon roll-over, and that is all that I am familiar with.
Brian
   / Roll over box blade: who has one? #13
I'm also curious as what the advantage if any there is to a rollover style. I've never used or seen one other than in a picture.
I have a regular style Woods BB with a floating gate and using the HTL can rip only, rip and fill the box, grade, smooth etc. etc.. Just depends on the angle of the HTL, this is all with the rippers up. For really deep ripping they can be dropped. Haven't needed to drop them since getting the HTL.
   / Roll over box blade: who has one? #14
Here is one on Ebay
Link
Ron
MikePA: Please review your message before posting it. It's simple not to create a long link that widens the entire thread. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses {} with square brackets in previous example. Alternatively, if you use the Instant Markup language URL link, the first prompt is for the URL. The second prompt is for a description. Do not simply paste in the URL again. Type a short description of the link.
Hey all...thanks for the feed back. I called the dealer that has the box blade for sale. It is in pretty bad shape and he was not real interested in sending any more photos. Thought it worked, but was not sure. But, do appreciate the info.
As for uses, once you use a roll over box blade, I don't think you will go back to a standard blade. One of the features I like is the ability to quickly change from cutting to dragging. Great for driveway and trail work. I have put in miles of tails on my property using the box blade and loader.
Brain: Yes, if you have a dealer I could call and check on price for Gannon that would be great. Thanks.
   / Roll over box blade: who has one? #17
Slippy, I will have that info for you Thursday, it's at work.
Brian
   / Roll over box blade: who has one? #18
CTyler, I guess that maybe the biggest difference from a std box blade would be that all the functions of the roll-over blade can be done with no aux hydraulics and never getting out of the tractor seat. /forums/images/graemlins/smirk.gif The actual workings probably aren't all that much different. Could be what each of us get used to is what we end up most comfortable working with.
Brian
Great! Thanks! /forums/images/graemlins/smile.gif
159118 (A60430)
159118 (A60430)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
