Rookie starting 640 makeover
   / Rookie starting 640 makeover #11
Soundguy
I probably should clarify it was spraycans of Rustoleum farm equipment paint. At the time I didn't have access to a compressor or spray gun so I painted the entire tractor with "spray bombs" as a lot of folks call them. I'm sure even the Rustoleum would have held up better if I had used spraygun & compressor.
I stripped down my Ford 4400 over the winter have started painting parts and putting it back together as its warmed up. This time I using PPG Omni epoxy primer and straight acrylic enamel w/o hardner. I'm pretty happy with the results except for the previously mentioned long cure time on the AE w/o hardner. I painted a Bush Hog loader with the same stuff a couple of years ago and its holding up pretty good. Maybe I'll break down and buy a supplied air system one of these days so I will feel comfortable using hardner.
Rick
   / Rookie starting 640 makeover #12
FWJ,
Do you use Crossfire paints & primers from NAPA? I've heard they have a good acrylic enamel but I'm wondering if they have an epoxy primer similar to Omni MP170.
Rick
I have used Crossfire. Lately I've been on a DuPont kick.... (There's a DuPont auto finish vendor about 10 minutes drive from the house....counter guy is a tractor nut....seems like a no brainer!)
   / Rookie starting 640 makeover #13
well, yeah.. that does make alot of difference.
spray can paint is super thin.. looks nice and even going down.. but just doesn't have any film depth.
soundguy
Soundguy
Rick
Guys, thanks for all the good advise. The tractor is stripped down to the body and ready for the first coat. Gotta getter down now before the metal starts to rust.
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2011 Chevrolet Suburban SUV (A51694)
2011 Chevrolet...
2013 International DuraStar 4300 2,000 Gallon Water Truck (A51692)
2013 International...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
