ROPS Modification and Lights
   / ROPS Modification and Lights
Hey, Cool I don't have a backhoe!:D
   / ROPS Modification and Lights #62
Too funny!! I'm glad you're still here and didn't go crawl off into some corner like I would have.
   / ROPS Modification and Lights #63
psdx said:
...I kept saying I wasn't going to intrude into this thread, but in the end I guess I couldn't resist. It's been said that by shortening the ROPS Gomer's tractor is less safe that it was. It makes for interesting reading, and I'm not complaining at all - but Gomer has taken a fair amount of grief over his ROPS modification. So I felt that a counterpoint was in order.
According to the Kubota specs, the fixed ROPS version of the 2630 is 11.56" shorter than the folding ROPS version. By looking at the picture, Gomer's ROPS still looks taller than a fixed ROPS version. And he is still using the original material that was designed to carry the rollover load. So if the fixed ROPS is sufficient at 11.56" shorter than the folding ROPS, then why is Gomer's modification so unnacceptable if it's as tall or taller than the fixed ROPS? ...not intended as kindling :) - just trying to offer a view that hasn't been mentioned.
Amen. I sure couldn't get worked up over this one....it is dangerous just to get on a tractor (or step into a bath tub for that matter) ya'll need to relax.
   / ROPS Modification and Lights #64
Toolguy said:
1*It is my understanding that the B2630 or B3030 needs to have the taller, folding ROPS if the tractor is equipped with a Backhoe.
If a BH is not going to be used then the shorter, non-folding ROPS is sufficient.
2*I don't believe the extra height is any safer, it just gives the operator more headroom when setting on the BH seat.
3*I prefer the shorter ROPS on my B3030. It fits thru all my doors and I don't have to trim the trees around my yard as high. It is a factory, stock unit so I have confidence it will work as designed if needed.
1*This is correct. As a matter of fact there was a thread about a Kubota dealer having to make good by replacing a short ROPS on a Kubota with the taller ROPS because the tractor was sold with a BH.
2*The taller ROPS certainly is a safety issue / especially with 3 point back hoes. People have been crushed to death with a 3 point hoe and short ROPS combination.
3*I would hope you aren't using a BH on your B3030 with a short REPS. especially a 3 point hoe!
   / ROPS Modification and Lights #66
who knew I was missing another rops cutting paranoia fest.
here is a pic of my cut rops.
I only cut 9 inches out of mine.
best description I've seen.LOL :D
   / ROPS Modification and Lights #68
The more I look at BX's the more I wonder if tall ROPS are a lightning hazard ;)
   / ROPS Modification and Lights #69
Just an FYI. When my dealer delivered MY BX-2350 I was told that any mods made to the ROPS system (drilling, cutting ) would void the warranty and the dealer would not pick up the tractor for servicing.
   / ROPS Modification and Lights #70
What does drilling a hole in a ROPS have to do with a powertrain failure???
I looked through the entire manual and specs before putting lights on mine, aside from not recomending it for safety reasons it never mentions anything about a warranty problem. In my previous life I was an aircraft technologist, specializing in airframe repairs. I can assure you that putting a couple 1/8" hole in the straight areas of the ROPS (not the bent areas mind you) to mount a light will not affect it's strenght! Now if you're putting a dozen 1/2" hole to mount a shotgun rack or something, that's would be a different story, but even then it would be hard to compromise the ROPS just by putting holes in the straight areas. Welding is a different thing altogether because you would be affecting the structure of the steel from heating it, but even then, what would that have to do with an blown valve train for instance???
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
2013 ISUZU NPR STAKE BODY TRUCK (A59904)
2013 ISUZU NPR...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
