Rotary Cutter Blade Nut
   / Rotary Cutter Blade Nut #21
For what it's worth, the cutter will likely slide off the jack stands when you try to take the nuts off if you use a cheater bar.
You might try picking it up on one side with the loader if you have one, stay out from under the dam* thing.
I'd tell you what I did, but the safety police would be beating my door down.
Sean
   / Rotary Cutter Blade Nut #22
Sean
(Bolded sentence) That's why I suggested using a long cheater bar. At least there would be an avenue for escape.
Might be safer (and better leverage) if the cutter was leaned up against a tree or other substantial surface and blocked to prevent it sliding. This is how I touch up my blades.
I do this when I pull my RFM blades off for sharpening too.
I never get under an implement if at all possible.
   / Rotary Cutter Blade Nut #23
Thats what I would recommend....:D
   / Rotary Cutter Blade Nut #24
My favorite cheap trick, (works sometimes), after spraying with lubricant, try tightening first. You might be amazed. Just a touch of tightening creates that magic little click when the rust breaks free.
Replaced the blades yesterday; everything went smoothly. You all were a big help--thanks! I figure I'll put an epilogue here, since half the things I read on this forum are archived threads.
Bought a 1-11/16" socket, an 18" slider bar (much cheaper than a ratchet) an 8" extender bar (to get me clear of the tail wheel), and a 3-foot length of 1" iron pipe. I soaked the nuts with WD-40 and let it sit for an hour or so. Then I took my new wrench and cheater pipe and broke the nuts free. Left them finger tight, though.
Rousted a nephew away from the basketball tournament and into service. Levered the cutter up in the air with a digging bar, and nephew slipped in four jack stands. Then I kicked the cutter as hard as I could from the side, and thought about how I'd feel about being underneath the cutter right then. It didn't budge visibly, so we proceeded. We did one blade at a time. Nephew loosened the nut the rest of the way, while I caught all the parts that fell. Then I took put the new blade and washer on the bolt and pushed the assembly into place from underneath while nephew tightened the nut enough to hold. When both blades were on, we levered the cutter back down on the ground. Chocked the tail wheel so it didn't roll. Now to tighten the nuts.
There's about 200 lbs of me and about 100 lbs of nephew. We were pulling about 3 feet from the bolt, so we'd need 150 lbs of force. The landscape rake weighs 160; we lifted it up in the air so we'd know what the right force felt like. (Answer: pulling for all we're worth.) Then we did that.
Two observations: 1. When I put the blades back on, my chest was under a piece of steel that would make a fair guillotine blade. Didn't like that much, but I couldn't see any other way to make sure the keys were in the keyways and the blades had the right play in them. 2. You can almost always get a 12-year-old boy interested in things involving really big wrenches.
   / Rotary Cutter Blade Nut #26
A lot of the old cutters had holes in the deck top for access to the blade bolts. Some farmers made holes on their own with the hot wrench. I think most companies have stopped putting in those access holes. Ken Sweet
   / Rotary Cutter Blade Nut #27
I am really surprised at some of you for using any lubricant on threads and nuts in a torque situation. Just about all torque figures are for dry fit. You can not get away with that on military aircraft, and probably civilian aircraft. I bet they don't do that on the space shuttle either. You can do whatever you want with your own machines, as the risk is yours.
Don't want to argue about it, as dry fit is the rule.
   / Rotary Cutter Blade Nut #28
My Land Pride has the hole in the deck, there's really no way to get at the nuts otherwise.
Sean
   / Rotary Cutter Blade Nut #29
G'day don't want to argue with you JJ i have never worked on aircraft so don't know it from that side of the fence, but every w/shop manual i have ised in the last 25 odd years has asked for a lubed thread on anything requiring specific torque value. A lubricated thread will always give you a tighter clamping load than a dry thread, i always lube the underside of the head as well. I am surprised they do not lube in the aviation industry. Like you i am not out to start an argument just stating what i know
Jon
   / Rotary Cutter Blade Nut #30
I've had to watch it if I did not use lube, as my little 403 JD cutter would start to lift off at full r.p.m.
A little lube fixed all that.:D
2010 UTILITY 53X102 DRY VAN TRAILER (A45677)
2010 UTILITY...
Telehandler Hydraulic Stabilizers (A45336)
Telehandler...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2007 Kubota RTV-900 4x4 Utility Cart (A45336)
2007 Kubota...
2014 UTILITY 53X102 DRY VAN TRAILER (A45677)
2014 UTILITY...
Mohawk 2-Post Hydraulic Auto Lift (A44571)
Mohawk 2-Post...
