Rotary cutter blade pics, advice?
   / Rotary cutter blade pics, advice? #21
You already have "lifting" blades.
   / Rotary cutter blade pics, advice? #22
I have several brush cutters over 15 yrs old that look much better than those . Look like you were cutting steel fence posts off . Dealer was full of it.
   / Rotary cutter blade pics, advice? #23
Still life left in those blades, run a grinder straight down the edge, even it out then resharpen them.
Yes, I was saying I'd inquire about alternatives, since clearly the lifting blades aren't doing well. (The cut is nice enough, the blades are another matter).
   / Rotary cutter blade pics, advice? #25
To be sure we are on the same page,the blades in post #16 are what's found on most cutters and have years of life left and you would only be wearing them out by sharpening. Are the blades in post #1 and post #16 one and the same (they look like totaly different type blades)? I totally agree that the rocks you describe shouldn't do much if any damage. At any rate,sharpening blades in post #1 only reduce's blade life without improving preformance "IF" they continue being used in same field. I wouldn't worry about LIFT or no LIFT,that's only relivent with lawn mowers. Claims of lift for pasture cutters is sales pitch hype. For the record,the ability to cut trees and brush increase's with mower quility and price. Bush Hog and Service mowers will cut anything the tractor can bend over and do as well in weeds and grass as anything you can buy at tractor supply or elsewhere. Yes,Bush Hog is a brand name so stop calling all cutters Bush Hogs.
   / Rotary cutter blade pics, advice? #26
You may need to look at flat blades if you can find them.
Set I just replaced on my 306...
The ends were rounded off, but other than that still in great shape
Probably 15-20 years old
No rocks here where I live.
   / Rotary cutter blade pics, advice? #27
Whaaaaaaat? :talktothehand: You are the only one that has used the term "Bush Hog" in this thread. :confused3:
Yes, those blades are the same blades. The post 16 pictures were taken in the spring after a couple of hours of doctoring up my field after it had a rough cut by someone else the year before. So those are basically new blades. (The whole cutter was new, bought in the spring). The post 1 picture is the exact same blades after I did the full cutting in the fall. If they look different it's probably (partly) because of the different perspectives of the camera relative to the blade, but of course the blade clearly also looks so thin and raggedy in post 1 I can see why you'd wonder, it's why I posted this topic. I didn't touch the blades with grinders or anything else at any point, just rotary cutter use.
Re: Bush Hog, I will sometimes use the term "brush hog" because that is what it is sometimes called around here, but yes, I realize it's not Bush Hog.
   / Rotary cutter blade pics, advice? #29
I think it's universally agreed the blades will not benifit from sharping but you say they don't do as well as they did earlier. May I suggest checking deck height to see if that might be some of the problem? Adjust deck so that blades are closer to ground when at front of deck. When blades are level or higher in front,weeds are clipped a secound time as they pass rear of deck. That secound clip leave's a ragged top on stem ,slow's blade and sap's horsepower. It's the same as cutting weeds with a machete. If you swing and cut weed mid-way between top and ground then swing a secound time attempting to cut stem 4" lower,the cut isn't as clean (if it cut's at all).
Thanks. The front is lower than the rear, in fact my concern is that it may be more than the 1 inch differential that is recommended in the operator's manual, i.e. that the rear wheel setting may be too high, thereby inclining the blade to strike downward a bit more when it does come in contact with things. So I'll be checking that difference next time around with some actual tools instead of a guesstimate.
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2007 INTERNATIONAL 9400I TANDEM AXLE DAY CAB (A56129)
2007 INTERNATIONAL...
24008 (A53422)
24008 (A53422)
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
