Rotary Cutter Gearbox...What to use?
   / Rotary Cutter Gearbox...What to use? #21
I would agree with the heat issues with 90% full, also foaming. If it has a fill level drain hole more often than not the oil level will be about halfway on the ball or rollers on the lower part of the bearing. if the load being transferred changes by 90 degrees ie. bevel gears etc. it would probably need an EP type gear oil.
a real quick way to check for water is a crackle test. by the time it looks muddy the fluid is emulsified with water and is in trouble.
Also like whitetiger said if your using grease a 00 is the way to go anything much thicker will probably just channel.
   / Rotary Cutter Gearbox...What to use? #22
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
