Rotary cutter / "position control"
   / Rotary cutter / "position control" #11
The 3 point lift cylinder is not pined to the lift mechanism in the tractor, it only pushes on a lever that in turn forces the lift arms lift as the cylinder extends. Regardless of where you have the lift arm height set, the lift arms can be pushed up moving that internal lever away from the cylinder so arms can raise. Then when the external push force is released the lever moves back until it hits against the cylinder and stops downward movement. So with a rotary cutter you have the position control set to hold say 2" above ground, the rear wheels drop in a 4" hole and the cutter hits the ground, it will push the arms up preventing any lifting force applied to the arms and not trying to raise the tractor. When the rear wheels climb out and back on level ground the cutter drops back to height you have set.
I am not seeing the compbination over-running coupler/slip clutch @ ASC, but did see this, which would be an easy (but not real cheap) fix:
FD1 PTO Slip Clutch-1-3/8 In. 6 Spline | Agri Supply #31951
Easier to install than replacing a unversal joint yoke. And, if it should turn out that the PTO shaft has been shortened to the extent that it is now too short for my aplication, the slip clutch might solve another problem.
   / Rotary cutter / "position control" #13
I had an overrun clutch on my Yanmar and it only slipped in one direction. It allowed the PTO to continue spinning when I clutched without pushing the tractor forward. It will not slip in the power direction so it is of no value as a slip clutch or safety mechanism to prevent damage to your tractors PTO.
I have never seen a bush hog that didn't have at least a shear pin for protection. Some of them will just be two flanges mated together. Each will have a small hole in them that has to be aligned and a bolt inserted of a specific size and grade. The bolt size will fit snugly into the two holes and Grade 5 is a commonly used bolt.
TO THE OP: Please post a photo of your bush hog PTO shaft with particular attention at the end where it attaches to the bush hog gear box. That is where the shear pin will be located.
   / Rotary cutter / "position control" #14
If i can "hang" the cutter from chains rather than relying on hydraulics, I would like to do that.
Positon Control returns 3-Pt to exact position it was in before, so position is repeatable. Most small tractors do not have Positon Control.
Here is a link to my thread reviewing check chain installation on Kubota B3300SU supporting a 48" King Kutter Rotary Cutter:
http://www.tractorbynet.com/forums/...ta-b3300su-zerco-check-chains.html?highlight=
Check Chain function, in lieu of Position Control, was highly satisfactory.
This is a photo of just one end, but both ends of the shaft are identical:
In fact, I am not sure which end is supposed to be the tractor end, and which end is the cutter end. The cutter gearbox has a splined input shaft identical to the PTO output shaft of the tractor. The cutter gear box input shaft is not smooth.
Neither end yoke on the shaft is set-up for a shear bolt, in the manner that this yoke is:
1486037 6 Lc6 Shear Pin Flange Yoke
Not a good close-up, but this is the cutter. One can barely see the splined input shaft. Definetly no slip clutch or shear pin @ the cutter gearbox. And nothing on the driveshaft itelf.
The guy was simply running it without any overload protection. But, I don't think it was run very much. The tractor that it was used with developed a bad case of black sludge in the fuel system.
   / Rotary cutter / "position control" #17
In my opinion those cutters that have the 1 3/8 splined input shaft are setup for a slip clutch. Some one has removed the slip clutch and just put a 1 3/8 to 1 3/8 shaft on it so you have no protection at this time. You need to buy a slip clutch and fit it to the cutter.
"...In my opinion those cutters that have the 1 3/8 splined input shaft are setup for a slip clutch. Some one has removed the slip clutch and just put a 1 3/8 to 1 3/8 shaft on it so you have no protection at this time. You need to buy a slip clutch and fit it to the cutter...."
That scenario would make sense: the cutter was purchased new by someone who used it very little, and it sat for several years before a second person bought the tractor & cutter. I am the third owner of the cutter, but the tractor had already been traded-off by the second owner (who could never get all the algae cleaned out of the fuel system.) I would bet it is likely that the slip clutch was on the tractor, and went with the tractor. I say this because i also bought a 5ft angle blade that had been part of this package, and the blade came with the top link from the original tractor, so I imagine that parts and pieces were not staying where they needed to stay. That would all make sense.
   / Rotary cutter / "position control" #20
Normally the slip clutch stays with the rotary cutter,/PTO shaft. the slip clutch usually has half of a PTO yoke on one end and a 1 3/8 splined female fitting on the other. But for some reason, they removed the slip clutch and found an old PTO shaft with 1 3/8 on both ends and put it on, or something similar. In any case you don't have any protection. so if you hit something immovable, something is going to break. It could be PTO components in your tractor.
2014 Cummins ISL 320HP 8.9L 6-Cylinder Turbo Diesel Engine (A55852)
2014 Cummins ISL...
2013 Ford F-550 Passenger Bus (A55852)
2013 Ford F-550...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2021 CASE IH Steiger 540 AFS Connect QuadTrac Tractor (A53485)
2021 CASE IH...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
