Rotary cutter rear u-joint shield??
/ Rotary cutter rear u-joint shield?? #1
Bobrown14
Upstate New York
LS MT352 w/power shuttle + cab
20221012_170735-jpg.766130
OK blew up my shield on my rotary cutter at the back end of my drive shaft where the shear pin is.
Shear pin broke and blew a hole and completely shattered tre shield. Pics attached.
Where can I purchase a new shield?
Rotary cutter is a Titan 1206.
Btw went thru a bag of shear bolts clearing some heavy over tractor cab high brush. Bout 10ish years old (the brush).
Any help sourcing the shear bolt cover greatly appreciated.
/ Rotary cutter rear u-joint shield?? #2
If it were mine, I’d just wrap duct tape around it if there is enough plastic material left to do that. A new one would probably end up in the same situation, and they’d probably charge you an arm and a leg.
/ Rotary cutter rear u-joint shield?? #3
Shouldn't be too hard to find. I found this in about 30 seconds...
/ Rotary cutter rear u-joint shield?? #5
Contact Titan and ask who their PTO parts supplier is. You may be able to buy direct.
Your local tractor dealer probably can help.
/ Rotary cutter rear u-joint shield?? #6
Titan won't sell direct, but most any tractor supply will have one. Also, going through sheer bolts like that, I think I would consider a slip clutch.
/ Rotary cutter rear u-joint shield?? #9
You need some grade 10 shear bolts.
/ Rotary cutter rear u-joint shield?? #11
/ Rotary cutter rear u-joint shield?? #12
I would never use higher than Grade 5 shear bolts. They're purpose is to shear to protect other components.
Tried that the after the first 2 times I blew it up. Useless couldn't even get the customer support person to understand what I was asking for even tho I gave her the part number from their website and helped her locate the webpage with the part number. Yeah wow....
Good point - this is the only implement I have with a shear bolt. I'm in the process of clearing some heavy brush in a field that was let go before we bought the property. Its great cover for the deer and glad I have a cab went thru a few hornet nests pheeewww they were pissed.
Kept hearing a banging sound on the glass was the soldier hornets attacking me. They were big AF too like 2" long. I started looking at the floor boards seeing if there was access thru where the gas/clutch pedals are. There's a few spots they could get in.
Once I get the brush cleared I prolly won't be breaking any more shear bolts. Im learning how thick a stem I can cut without breaking the bolt.
I'm using grade 2 shear bolts. Maybe I should get some stronger bolts for this brush clearing job.
/ Rotary cutter rear u-joint shield?? #16
The owners manual that I found online states that you need the number 2 shear bolt.
you might try Mowing with the mower a little higher in the thick stuff and then come back through a second time at the proper height that you want. This may allow the cutter to chop the material easier and save a sheer bolt or two.
Also drop your travel speed way down.
/ Rotary cutter rear u-joint shield?? #17
I hear you!
I'd take the assembly to the tractor dealer to see if they can find a match from their PTO suppliers. If you have some sort of mystery chinesium product you may have trouble.
I find telephone customer support to be iffy these days and I'm lucky to find a knowledgeable support person on the other end. I'm lucky to have a few go-to guys at my local dealerships that are willing to take the time to help.
These guys stock various PTO parts
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
2016 GENIE S65 TELESCOPIC BOOM LIFT (A60429)
2016 GENIE S65...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
